Results 1 to 15 of 22
    Nov 2019
    Canada
    Cylinder Bore Repair
    So I found a good 2016 short block, it had sunk but was supposed to be in good condition. The guy who has it coated the cylinders with ATF. It appears that something has now pitted out those liners. I haven't bought this block yet, but theres not tons of them out there to pick from either.
    What would you guys do with this. Originally these are nikasil coated. He tells me he has a shop that recoats them. Or should I have a steel sleeve put in? Whos the "go to guy" to send this thing out for machine work?
    Or should I pass on it and keep looking?
    The motor is a 250 VMax SHO.
    (I posted this on the "porkchop build thread" earlier, but wasn't getting any responses, so figured I would post in the higher traffic Technical Discussion section)
    Blake
    www.InjectorService.com
    Call/Text - 204-326-0390
    clean it with some muratic acid and see what happens.
  3. Likes David - WI liked this post
    Aug 2016
    texas
    Southern Marine and Machine out of florida, Found these guys on facebook and he has tons of videos in his machine shop sleeving these yamahas
    If it's all 6 you might as well have Millennium or US Chrome strip it and re-plate? Or not?
    Dec 2001
    I want to close my eyes and grit my teeth........Find a better deal.
  7. Likes racer, rgsauger liked this post
    Nov 2019
    Canada
    This is the option the seller suggested. Have you used Millennium before? He was going to get me a quote.
    Nov 2019
    Canada
    Quote Originally Posted by slim95 View Post
    Ill check them out. I have heard of guys putting steel sleeves in them. What do you guys with plated mercs do? Sleeve em? Junk em?
    (sounds like Dave might junk em! )
    Also not sure about the acid, Ive used it before to take aluminum off with good success. The seller says it is definitely pitted, and according to him he does a lot of this sort of stuff. I mean I could just buy it and play with it myself to see what I can accomplish.
    Quote Originally Posted by InjectorService View Post
    The reason I said that is that to re-nikasil one cylinder you have to strip them all and re- plate them all, so it's usually cheaper to sleeve one but if you have 3 or 4 bad ones re-plate is probably cheaper. But Dave & thrones guys do more of these I ever will.
    Either US Chrome or Millennium... they do them all the time.
    Los Angeles Cal.
    Dave is correct, if you do send it to be re-plated make sure and use stainless bolts on all the thread holes the process eats some of the threads out of the aluminum.
  12. Likes David - WI liked this post
    Aug 2009
    mpls,mn
    nicasil plated cyl for a 4 stroke.Interesting ?
  14. Likes stoker2001 liked this post
    Quote Originally Posted by racervboat View Post
    We were buying aluminum bore, dual-bearing "industrial" Briggs motors, boring them 0.140" over and having them nicasil plated back in the 90's for methanol powered go-karts.
  16. Likes rgsauger, JR IN JAX liked this post
    With the cylinders looking that way a guy has to wonder what crank and bearing surfaces look like.
  18. Likes crazy horse liked this post
  19. #13
    Nov 2019
    Canada
    Yeah.... I'm starting to wonder if I will pass on this mess. I "think" my crank is ok in my motor. Weights are a little beat up, but I'm sure we can work around that, as long as its not bent, so I'm not super concerned about that.
    He did chop the price in half if I take it as is though, so.....
    These blocks are so hard to find, and finding a 2016+ is even harder. They changed some of the cooling system/routing from what I understand.
  20. Likes Dave Strong liked this post
  21. #14
    Mercedes and Mahle developed Nicasil in the 60's . Porsche and Benz still use it to this day. Biggest drawback with using it on four strokes is todays oil doesn't have the sulphur and zinc that it once did.
  22. Thanks Markus thanked for this post
    Likes racervboat, Dave Strong liked this post
  23. #15
    I still say the Mahle Nicasil was better than the US chrome stuff.
  1. Increasing cylinder bore
    By Captain75 in forum Technical Discussion
    Last Post: 11-02-2014, 02:06 PM
  2. cylinder bore question.
    By N Wolf in forum Technical Discussion
    Last Post: 06-18-2014, 03:25 PM
  3. Mercury Tech: 2.5 Cylinder bore pictures info
    By Slimm in forum Technical Discussion
    Last Post: 06-01-2014, 11:40 PM
  4. Cylinder bore wear vs time
    By Carter Powell in forum Technical Discussion
    Last Post: 03-03-2009, 10:34 PM
