Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 95
Thread: The jeep thread
  1. #46
    Jul 2005
    AZ
    I had the bilstein 5100 In my trucks I thought they were great.
  2. Likes CDave liked this post
  3. #47
    Just bought another 4 , exactly the same, extended 4". Big Square body Sub HD K20. They changed the valving, consolidated a couple lines of application. Turned them into minivan shocks. Cleaned and dressed the old rears and hung them back on. They are better in and out than the new ones, drove like a vomit ride with the new ones. Front almost like the previous but not quite.
    Called them prior to ordering, they swore they didn't change a thing, called them back and let them know after I put the old ones back on. Nothing stays the same in this age of profit taking greed.
  4. #48
    PARADISE /Naples
    Replaced the original springs with some custom springs. It sits up good and even rides good. We have a place that re-arches and custom builds them here. Bilstein shocks too. Drives like a sports car.
    My last four pick-up trucks I took the rear leaf packs off and to Florida Spring to just re-arch the rears, you have to add a leveling kit to the front to get larger tires on Dodges, the 2500's are stiff enough, but I add Timbren rubber springs in the rear because my chippers have 2,000 tongue weight, I once tried them on the front but if you went over a speed bump you about hit your head on the roof, I would only recommend them if someone plowed snow with that extra weight up front.
  5. #49
    8 Post(s)
    I bought a Jeep Wrangler Unlimited in 2008. I took the Rubicon model cause of the goodies that came with it, like the lockers and the anti sway bar disconnect. I haven't done much to it except for a mild lift and 35" BF Goodrich mud terrains. It's been good to me for 12 years now. The torque converter was replaced at 60,000 miles, other than that, light bulbs, brake pads, 2 brake calipers
  6. #50
    Quote Originally Posted by CUDA View Post
    I have 4 leaf front, 10 in rear , arched up , rears are over 3800lb load per stack, stopped counting after 8 .
    Like the Jeep with the little diesel!
  7. #51
    Quote Originally Posted by sharpeye Mike View Post
    Get it over to Krown, every year, everywhere. Been at it for decades , nothing better.
  8. Thanks sharpeye Mike thanked for this post
  9. #52
    PARADISE /Naples
    Well then you better fly down here for Sundays race, right up your ...
    https://www.swampbuggy.com/
    https://www.swampbuggy.com/history
  10. #53
    Sep 2017
    Ashland city tn
    Which brands, look at the actual sidewall at the bead, small print ply count description, it will have the number and makeup of the ply. Not the letter comparison letter rating.
    You can have 8 ply tires with E (10ply) rating, the letter is a comparison rating only.
    Best is load lb rating at psi, that's the real world.
    As mentioned above, same size tire, both 8 ply 5 tread + 3 sidewall. One has a E rating with 3200lb at 60+psi, the other better tire has 3400+lb at only 45lb but is rated D and has many other advantages over the E comparison rated tire.
    Ya , I always look at my plys , I don't assume the ply because the letter rating , I've been a big fan of mud terrain tires and only tires I run on all my trucks for last 20 yrs,
  11. #54
    Dec 2004
    CT
    My 1951 Willys
    21 Cougar Mtr
    21 Superboat
    Hydrostream Venus
    Hydrostream Vegas
    22 Apache Scout
  12. Likes FMP, CDave liked this post
  13. #55
    Quote Originally Posted by Merc 2.5 View Post
    Just looked at my original '70s Goodyear cushion milers true 10 ply , 6 tread + 4 sidewall, 'D' rated.
  14. #56
    Sep 2017
    Ashland city tn
    Well been little while since we got the jeep , I've put it in some places I'd never thought it go for sure , but I been working on it along the way , and yet still so much to do suspension wise it's now got lots and lots of goodys in suspension and drive train also lockers , 37 13.50s , 4in lift , 4.88 gears, etc. It's technically the wife's, so she named it , which I rekon it works
ID:	484835Click image for larger version.
  15. #57
    Jun 2002
    Winter Haven Fl.
    We have gone to 2 event the last one had over 2000 Jeep’s, great father son time now I need to get one.
  16. #58
    Jun 2002
    Winter Haven Fl.
  17. #59
    Jun 2002
    Winter Haven Fl.
  18. #60
    Jun 2002
    Winter Haven Fl.
  1. The un-official I love my jeep thread
    By Pro300x24LD in forum The Scream And Fly Lounge
    Last Post: 02-16-2010, 03:44 PM
  2. The New Jeep!
    By INXS in forum The Scream And Fly Lounge
    Last Post: 03-16-2009, 09:11 PM
  3. Checkout the new Jeep!
    By Fast Fig in forum Other Motorsports
    Last Post: 09-28-2006, 01:19 PM
  4. Jeep 3.7?
    By hevysrf in forum Tow Vehicles and Trailers
    Last Post: 01-07-2006, 12:23 PM
  5. Jeep Stereo???
    By Boaterbum in forum General Boating Discussion
    Last Post: 11-28-2003, 09:32 AM
