Results 7,531 to 7,545 of 13257
09-25-2020, 05:52 PM #7531
6000 RPM
- Jun 2009
- Georgia
- 1,023
- 243
- 9
- 385
- 43 Post(s)
Something got lost in the translation. The rotary is a 4-stroke. What I was trying to say it took OMC 10 years to realize a lower center on gravity by using a 6" mid section on the V-8 while the rotary had no mid section back in '73. Many of the features used on the rotary were later used on the 2-stroke racing engines. Know why there are no 14/23 Rotary gearcases left?; they were scavenged for parts for the V-6/V-8 Programs.
peterse90 thanked for this post
09-25-2020, 05:58 PM #7532
6000 RPM
- Jun 2009
- Georgia
- 1,023
- 243
- 9
- 385
- 43 Post(s)
Don Kueny and Jim Nerstron were busom buddies. I can't speak of his attitude towards racing, but he had an extreme hatred for the rotary and anyone involved with it. Kueny being appointed Chief Engineer to replace Hulsubus was the direct cause of the entire rotary engineering team leaving OMC within a year of his appointment.
09-25-2020, 06:34 PM #7533
Well.. I spent 2 weeks with Don Kueny over in Sweden and pretty sure it was 1994.
If I remember correct he retired from OMC the year before.
A very interesting man and he told me a lot of good and fun stuff.
A great man. Don’t remember him talking about the rotary, but we talked about mostly production OMC outboards.
We did visit his home in Kenosha a few years later with our motorhome.
I did google Don Kueny and found this..
powerabout thanked for this post
Lake X Kid liked this post
09-26-2020, 09:32 AM #7534
5000 RPM
- Dec 2005
- Keswick, Ontario
- 602
- 105
- 111
- 471
- 293
- 8 Post(s)
When you think back on it, I think the focus was more on the 'revolutionary' combustion design of a rotary and that OMC stacked 4 of them. If I remember correctly very little was made of the fact that they were 4-strokes. Now looking back over 45 years ago, think now with the introduction of Merc's new 4-stroke Formula 1 engine just how ahead of the curve the OMC rotaries were. Same could be said about the OMC V8's.
Timing is everything !!!!
Now I know why when I heard Jimbo run a rotary in Peterborough, Ontario 1973 it sounded so different.
Instigator liked this post
09-26-2020, 09:44 AM #7535
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,313
- 1052
- 409
- 4692
- 2167
- 9 Post(s)
09-26-2020, 02:17 PM #7536
6000 RPM
- Jun 2009
- Georgia
- 1,023
- 243
- 9
- 385
- 43 Post(s)
Not only were the rotaries a 4-stroke, the exhaust cycle lasted for 270 degrees of crank rotation for each flank of the rotor. Couple this with the fact 2 rotors were exhausting at the same time and for part of the cycle all 4 were exhausting; aka a unique sound. In one cycle of the crankshaft (360 degrees) all 4 rotors exhaust. In fact exhausting is continuous for each rotor. As the apex seal closes for on flank of the rotor it opens the next flank to exhaust.
lars strom liked this post
09-27-2020, 09:22 AM #7537
6000 RPM
- Nov 2006
- 1,728
- 15
- 177
- 85
- 770
- 41 Post(s)
09-27-2020, 09:44 AM #7538
6000 RPM
- Jun 2009
- Georgia
- 1,023
- 243
- 9
- 385
- 43 Post(s)
It didn't have one. There are 2 types of rotaries, both of which are 4 strokes. The rotor is a captive heat source, that is there is no external way to remove heat from it. Mazda uses what is call an oil coiled rotor. Oil is circulated inside the rotor to cool it and then run thru a heat exchanger to remove the heat. A pressurize oil system also allows the used of babbitt bearings, but requires oil seals in the rotors to insure oil isn't leaked into the combustion area. The OMC race rotary (and snow mobile) was charged cooled. The incoming gas/air charge was passed the rotor cooling it. Oil was mixed with the gas similar to a 2-stroke to lubricate the roller bearings. Using the charge to cool the rotor heated it up considerably resulting in reduced airflow (less volumetric efficiency). This was the trade off of the 2 cooling methods. The oil cooled had higher volumetric efficiency; HP, at the expense of more parts, more weight and higher friction losses. The charged cooled is simpler and lighter but lower HP.
09-27-2020, 01:15 PM #7539
Gene Thibodaux won the 1986 F1-V8 World Championship title but sadly passed away 2016.
http://svera.se/blogg/gene-thibodeaux-won-the-1986-f1-v8-world-championship-title-but-sadly-passed-away-2016/
09-27-2020, 01:47 PM #7540
7000 RPM
- Dec 2002
- South Florida
- 2,385
- 170
- 593
- 13 Post(s)
In the mid 70s I was working on a crash fire unit at a local airport. An airline pilot was trying a new approach to unlimited air racing. He designed and built a small twin engine airplane to compete with the warbirds that made up the class. His plane was powered by 2 Racing Beat Mazda rotary engines. Every time he flew it the airport got noise complaints. I only heard it with both motors running once. It was LOUD and HARSH. Even with only one motor running it was unpleasant. The motors were arranged in a puller/pusher configuration and he never got the rear engine to cool properly. One result of this was we got to watch him land it a lot since he would have to declare am emergency each time. I think he finally ran out of money and patience.
09-27-2020, 02:39 PM #7541
I was listening to this #03 Evinrude powered ScottiCraft for close to 6 hours in Paris 1974.
(The two drivers was Jimbo McConnell & Barry Woods)
I don't remember this unique racing outboard extremely loud but a very special great sound. @Rotary John
09-27-2020, 03:12 PM #7542
7000 RPM
- Dec 2002
- South Florida
- 2,385
- 170
- 593
- 13 Post(s)
I think the OMC rotaries may have been run down here once. I am pretty sure I was not there if they did since they were pretty distinctive. So I have not heard how they sounded. I have heard a few Mazda race cars and can say that it must be a acquired taste. Most places required them to run mufflers.
09-27-2020, 04:11 PM #7543
09-27-2020, 11:06 PM #7544
09-28-2020, 07:48 AM #7545
Evinrude & Johnson Racing 1967+
By Mark75H in forum Outboard and Racing HistoryReplies: 46Last Post: 04-24-2023, 09:58 PM -
V8 Johnson/evinrude Outboards
By baassoc in forum General Boating DiscussionReplies: 23Last Post: 04-17-2020, 06:21 AM -
D and E Class OMC outboards, Johnson 60 and Evinrude 75
By smokin'joe in forum Outboard EnginesReplies: 0Last Post: 05-21-2017, 09:24 AM -
I made a video showing the tear down of a Johnson Evinrude 1975 nitro gear case
By regrp in forum Technical DiscussionReplies: 0Last Post: 10-02-2014, 09:07 PM
