    South Florida
    Mercury's most enduring engine platform and my sentimental favorite. Did most of my racing in front of those motors.
    ...although styled differently than what your used to......it looks like 1997 was the last year. pretty sure anyways...
  3. Thanks Mark75H thanked for this post
    Likes Mark75H liked this post
  4. #17958
    If you go back to the earliest 40ci 4 cylinder, its the KF9 - if you insist on starting the line with the 44ci Mk58 - either way I bet its the longest running most produced outboard ever
  5. Likes GENE LANHAM liked this post
  6. #17959
    Fond du Lac WI
    "Long about that '96/'97 timeframe I was sent a proto 4 cyinder 4 cycle "500" to rig and show at dealer meetings. At the Whaler show at Sonesta, I had it on a 13' Whaler, being the smallest in thier in water fleet, it was the first boat in line when dealers came onto the docks. Just before they arrived I fired it up and just left it idleing - dealers would come walking by, and do a double take - only way you could tell it was running was the tell tale stream hitting the water, you could not hear it.
  7. Likes Lake X Kid, Mark75H liked this post
  8. #17960
    Quote Originally Posted by bernie View Post
    "only way you could tell it was running was the tell tale stream hitting the water, you could not hear it."
    Damn right! Been around boats since 3, now 70. About 15 years ago my neighbor bought a new Suzuki 175 (think) for his CC. I went down to the launch dock and checked it out. In the water, and I notice the tell tale stream., but hear NO NOISE? Said (yep serious as dumbfounded) "this got a electric water pump?" "Nope ITS RUNNING!" Looked the and saw exhaust bubbles! Told him it needs zoomies and megaphones!
  9. Likes Mark75H liked this post
  10. #17961
    South Florida
    The last couple of 44ci Mercury 500s I raced were just about indestructible. By the early 70s pretty much all the weak spots in the motors had been weeded out. The only problem the motors of that vintage had was loose timing belts. I understand that the next generation eliminated that issue. I was running those motors at 6000 rpm and more even in marathons with never a hiccup. My last season running one in SD it would push my McCall v-bottom an honest 62 mph on a calibrated Keller speedo. Those motors would run all season with very little attention as long as you didn't loose a water pump and get it hot or flip the boat and sink it.Click image for larger version.
  11. Likes Lake X Kid, moparbarn, GrewuponLakeX liked this post
  12. #17962
  13. Likes GrewuponLakeX liked this post
  14. #17963
    ...how do you think keller calibrated a keller speedo? (they are a diaphram air pressure gauge) ...anyone know?
  15. #17964
    ...2us70, your sd boat was doing 62. how fast were the se boats going back then?
  16. #17965
    Put a Merc 500 on a 13 Ally after blowing up the 70 racing against the Rude Stingers. Went to a play boat, 2 seater and got a honest 50 MPH out it. GREAT little motors! Still rigging it here..
    The way I rolled in the 70's!
  17. #17966
    Southern California
    30 Post(s)
    50 horsepower range, seems to be the maximum differential, on a production engine sharing the same block.
    The 153 cubic inch V6, has Merc models 150 horsepower to 200 horsepower engines.
    And with the same stroke.
    Did they de-tune the model 150?
    Did the inline 6 Mercs 1000 and the 1500, share the same block too?
Name:	1994 Merc specs..JPG
  18. #17967
    Quote Originally Posted by Lake X Kid View Post
    The 150 XR6 and 150 EFI were 2.5, the carb 150 was still a 2.0L. All so called 150hp, betting the 2.5 had better performance but more cost.
  19. #17968
    South Florida
    Middle 70s.
  20. #17969
    South Florida
    I don't know the procedure but in 1973 my Keller got all wonkey and wouldn't read over 68mph. Caused me a great deal of confusion at Nationals that year. I sent back to Keller and they repaired and recalibrated it. It worked fine the rest of the time I used it. Those Keller speedos were the best we had in those days before GPS.
  21. #17970
Name:	GCM Allison.jpg
    Quote Originally Posted by 2us70 View Post
  22. Likes GrewuponLakeX liked this post
Page 1198 of 1889 FirstFirst ... 198 698 1098 1148 1174 1175 1176 1177 1178 1179 1180 1181 1182 1183 1184 1185 1186 1187 1188 1189 1190 1191 1192 1193 1194 1195 1196 1197 1198 1199 1200 1201 1202 1203 1204 1205 1206 1207 1208 1209 1210 1211 1212 1213 1214 1215 1216 1217 1218 1219 1220 1221 1222 1248 1298 1698 ... LastLast
