Results 17,851 to 17,865 of 28411
Thread: Mercury Through The Years...
07-05-2020, 03:12 AM #17851
Screaming And Flying!
- Dec 2001
- 9,487
- 271
- 191
- 1979
Mk 75 gearcases were just big kg7/ kg9 cases.....Easer to have the prop gear behind the driveshaft....
Mark75H liked this post
07-05-2020, 10:21 AM #17852
The Historic Photo Master
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-05-2020, 06:31 PM #17853
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
...'76 Mercury Brochure continued...
07-05-2020, 10:29 PM #17854
Dave Strong liked this post
07-06-2020, 07:56 AM #17855
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
FMP liked this post
07-06-2020, 08:19 AM #17856
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-07-2020, 07:06 PM #17857
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-08-2020, 09:14 AM #17858
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-08-2020, 10:29 AM #17859
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-08-2020, 10:46 AM #17860
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-08-2020, 06:06 PM #17861
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
07-09-2020, 09:23 AM #17862
5000 RPM
- May 2003
- Fond du Lac WI
- 815
- 18
- 85
- 72
- 408
I was heavily involved in the Gnat's production - first in FDL where we machined blocks, rods, cranks,misc. aluminum parts, and the first gearcases and internals. Someone then found a Japanese vendor for the cranks - but because I had the gauging to check them, they came to Plant 4 before assembly. Dimensions were all over the map, but because they needed them on the line, someone (not me) signed a deviation to use them. This pissed me off, I had our secretary go back through our scrap tickets and found 800 cranks that according to the new dimensions, would have be useable.
Then the project went to Belgium, good riddance. Later, it came back to the Juarez MX plant for casting, machining, and assembly. Labor savings was like $70 per engine!
Guess who got sent down there for 10 weeks to get the machining inspection going, YEP you guessed it! HAd a 12 station dial machining center that came from Belgium to do the gearcase. Could not get it to run right, it would misfire and crash right from the get go. Then someone realized it wa wired for the 50 cycle electricity in Europe, so all new electric motors were installed to cure that problem.
My biggest problem was explaining to the Mexican people assigned to inspection what an inch was - they are metric minded. I finally took all the numbers off the gauging and highlighted the dimensional bands in green, yellow, and red - they understood stoplights - green on the gauge was OK, and so on.
Only good thing about the Juarez trip was the extremely pretty Mexican girls working in the plant! I was not married at the time, but they could not go out with us Gringos - their Mamma would have a fit!Last edited by bernie; 07-09-2020 at 12:59 PM.
07-09-2020, 10:13 AM #17863
7000 RPM
- Dec 2002
- South Florida
- 2,101
- 170
- 597
- 13 Post(s)
07-09-2020, 11:04 AM #17864
6000 RPM
- Nov 2006
- 1,224
- 18
- 183
- 86
- 786
- 45 Post(s)
Variability - Production & Global Economics
It's funny how some business strategist will propose placing production work in some other country just to save a buck on evil "labor" then to find all these other variables in the production system equation. Early Honda Civic engine assembly used a selection of 4 different crankshaft bearing shell combinations to absorb the variability in the crankshaft dimensions. We found that economics got wrapped up into the picture as well. If we gave our vendors a deal on the tolerances (loose) we expected a deal on the per item cost (cheaper) or vice versa. We also learned that educating our vendors on how their production component fit into the overall production objective worked far better than just "spec'ing" it out to them.
bernie liked this post
07-09-2020, 11:10 AM #17865
looks like MX15 with 650XS
Mercury racing line-up thru the years
By triplestroker in forum Outboard and Racing HistoryReplies: 13Last Post: 05-08-2014, 04:31 PM -
What years were 2.4 & 2.5 blocks built by Mercury?
By Knothead in forum Technical DiscussionReplies: 28Last Post: 06-18-2013, 06:22 PM -
1976 Mercury 65 hp first start in 12 years
By DaveS8984 in forum Technical DiscussionReplies: 8Last Post: 07-26-2011, 06:07 PM -
Looking for an old Mercury commercial, about 10-11 years old
By Ron V in forum General Boating DiscussionReplies: 0Last Post: 04-27-2006, 08:31 PM
have a great 4th of july weekend everybody...
