Page 108 of 299 FirstFirst ... 8 58 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 158 208 ... LastLast
Results 1,606 to 1,620 of 4484
  1. #1606
    3 rings per piston means rough sealing surface used?
    Oct 2009
    Gonzales, La
    2 compression rings and 1 oil scraper is pretty typical for a 4-stroke.
  3. Likes XstreamVking liked this post
  4. #1608
    NR500 .. they named that one right … still "Not Ready" after 30+ years …
  5. #1609
    Originally Posted by Capt.Insane-o
    My father was an apprentice at Grey Iron when the 396 was being developed as a "marine motor" sh*t in the valve train doesn't even point in the right direction, how that pile of junk became ballyhoooed as one of the greatest motors of all time is way beyond me.
    Fugimotosan says :
    ...so true. as you know, they morphed into the 427, 454, & so on, over the years. you would have thought GM could have fixed all those decades of bad valvetrain production. nope! as they came from GM, a large percentage failed. particularly the ones that were marinized by marine engine suppliers in stock form. it was up to the customer to spend the bigger dollars to upgrade with an aftermarket valvetrain. ridiculous. sustained 5,000 rpm? hell no.
    _______________________________________________________________________________
    The simple answer is :
    If they put the valves inline .. it would just be another small port, small valve motor that runs 1/3rd of the valve up against the chamber and cylinder wall... you know, like a .. 383 / 440 NoPar ..
    Common sense dictates :
    Going with the "Porcupine" head , the valve moves away from the wall as it opens and closes . Splaying the valves also allows the ports to be much bigger with a better line of sight entry ..
    She's so fine, my 409 :
    The valve angle , rocker arm and push rod all run on the same plane . The only change of direction is at the lifter / pushrod junction . The only people I know that had problems had the wrong length pushrods in place or had sacked out valve springs . The rocker needs to seat on the outer 1/3 rd of the valve stem . Then sweeping to the inner 1/3rd at full lift , then back again as it closes .
    Pre Limiter :
    Being that they would rev freely from the airflow capacity .. it's easy to over rev the motor and hurt parts . Not the motors fault … is it ..
    I've had short stroke Big blocks that would go 9000 .. and hurt nothing ..
    The 500" Pro / Stock guys run them up in the 11,000 rpm range ..pass after pass
    It's not 1965 anymore ….
    They are popular because :
    They came with steel cranks from the factory. 4 bolt blocks. 6 bolt heads. 4.840 bore space . Rocker pedestals are also 4.840 apart .. simple . The same basic 396 platform goes to 632 cubic inch's . And up to 1000 + ci in todays world of CNC machining . Did I mention airflow …
    Chaz= thinkin, Dick Keinath has passed on , but his design will live on way past any of us …
    <strike></strike>
  6. Thanks racervboat thanked for this post
    Likes Robby321, Mugs914 liked this post
  7. #1610
    Shreveport, La.
    Same thing works for the canted valve Ford Cleveland small block.
  8. #1611
    Quote Originally Posted by Da Bull View Post
    I almost posted something about seeing the Gapp + Roush "Tijuana Taxi" run at Miami~Hollywood and Gainesville …
  9. Likes AZMIDLYF, moparbarn liked this post
  10. #1612
    Smokey told Chevrolet in the early 1950's that the "new" smallblock head was too short to get the ports up high enough to get the short turn radius big enough to , make the turn , straighten the flow .. and use the whole valves circumference . They didn't listen to him , but Richard Maskins sure did ..
    Get away from that wall …
  11. Likes Robby321, Mugs914 liked this post
  12. #1613
    I wonder what kind of boring/honing machine they used.
    CNC done.
  13. #1614
    Watched this a while ago...he is a modest genius.
  14. Likes Lake X Kid liked this post
  15. #1615
    ...very familiar & a great design. and in stock factory form, had no rocker/valvetrain issues like the bbc.
  16. Likes Capt.Insane-o liked this post
  17. #1616
    Fugimotosan says :
    Pre Limiter :
    <strike></strike>
    ...again, very familiar with the porcupine/canted valve design chaz. i was in warranty for decades with these engines in ''stock" factory versions. too many warranty replacement units to count. i have hi-performance bbc experience as well, which is not what i was referencing.
  18. Likes Capt.Insane-o liked this post
  19. #1617
    PARADISE /Naples
    Never got into big blocks even though they made them in my town of Tonawanda I believe it was called the Mark IV line, 50 years... no more.
    I had a 64 Vette 327 with a few extra parts that would beat any big block around If I raced from a press, about died in it racing a new 440 Cuda this was 1971, going over a R/R crossing, while driving me to the Hospital the 440 6 pack Cuda owner could not believe he was getting beat by a 327, power to weight ratio and a motor that could breath real well.
    Small blocks sing high notes
    j
  20. #1618
    Mar 2016
    cincinnati, ohio
    Ok, who won, you or the Cuda??? And if you are a Chevy guy, why are you called Cuda???
    j[/QUOTE]
  21. #1619
    back in the late sixties/early seventies, the factory big block cars(no matter which one you choose of the big three) could not get any traction. for acceleration OR handling. those goodyear polyglas gt's didn't stand a chance, lol. or the firestone wide-ovals. they just sat there and sizzled.
  22. Likes HydroSkreamin, Mugs914 liked this post
  23. #1620
    Southern California
    30 Post(s)
Name:	4th of July - Lake X Tower.JPG
  24. Likes AZMIDLYF, racervboat, Capt.Insane-o liked this post
  1. Interesting and sad photo
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 09-27-2017, 03:49 PM
  2. Photos: *** Photo Contest Finalists!*** < Vote For Your Favorite Photo Here>
    Last Post: 02-15-2013, 02:08 PM
  3. Photos: [photo contest] *** Post your BEST photo HERE, and there will be a winner ***
    Last Post: 01-27-2013, 07:21 AM
  4. Body shop in 1920 - Interesting photo
    Last Post: 11-28-2009, 10:26 PM
  5. Classic Allison Photo #5 - VERY Early Race Photo
    Last Post: 03-10-2006, 09:38 AM
