Results 1,606 to 1,620 of 4484
Thread: Interesting Photo...
07-04-2020, 09:37 AM #1606
Screaming And Flying!
- 15,072
- 407
- 1455
- 6043
- 11685
3 rings per piston means rough sealing surface used?
07-04-2020, 10:00 AM #1607
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
2 compression rings and 1 oil scraper is pretty typical for a 4-stroke.
XstreamVking liked this post
07-04-2020, 10:31 AM #1608
NR500 .. they named that one right … still "Not Ready" after 30+ years …
07-04-2020, 11:16 AM #1609
Originally Posted by Capt.Insane-o
My father was an apprentice at Grey Iron when the 396 was being developed as a "marine motor" sh*t in the valve train doesn't even point in the right direction, how that pile of junk became ballyhoooed as one of the greatest motors of all time is way beyond me.
Fugimotosan says :
...so true. as you know, they morphed into the 427, 454, & so on, over the years. you would have thought GM could have fixed all those decades of bad valvetrain production. nope! as they came from GM, a large percentage failed. particularly the ones that were marinized by marine engine suppliers in stock form. it was up to the customer to spend the bigger dollars to upgrade with an aftermarket valvetrain. ridiculous. sustained 5,000 rpm? hell no.
_______________________________________________________________________________
The simple answer is :
If they put the valves inline .. it would just be another small port, small valve motor that runs 1/3rd of the valve up against the chamber and cylinder wall... you know, like a .. 383 / 440 NoPar ..
Common sense dictates :
Going with the "Porcupine" head , the valve moves away from the wall as it opens and closes . Splaying the valves also allows the ports to be much bigger with a better line of sight entry ..
She's so fine, my 409 :
The valve angle , rocker arm and push rod all run on the same plane . The only change of direction is at the lifter / pushrod junction . The only people I know that had problems had the wrong length pushrods in place or had sacked out valve springs . The rocker needs to seat on the outer 1/3 rd of the valve stem . Then sweeping to the inner 1/3rd at full lift , then back again as it closes .
Pre Limiter :
Being that they would rev freely from the airflow capacity .. it's easy to over rev the motor and hurt parts . Not the motors fault … is it ..
I've had short stroke Big blocks that would go 9000 .. and hurt nothing ..
The 500" Pro / Stock guys run them up in the 11,000 rpm range ..pass after pass
It's not 1965 anymore ….
They are popular because :
They came with steel cranks from the factory. 4 bolt blocks. 6 bolt heads. 4.840 bore space . Rocker pedestals are also 4.840 apart .. simple . The same basic 396 platform goes to 632 cubic inch's . And up to 1000 + ci in todays world of CNC machining . Did I mention airflow …
Chaz= thinkin, Dick Keinath has passed on , but his design will live on way past any of us …
<strike></strike>
racervboat thanked for this post
07-04-2020, 12:06 PM #1610
Same thing works for the canted valve Ford Cleveland small block.
07-04-2020, 01:09 PM #1611
07-04-2020, 01:20 PM #1612
Smokey told Chevrolet in the early 1950's that the "new" smallblock head was too short to get the ports up high enough to get the short turn radius big enough to , make the turn , straighten the flow .. and use the whole valves circumference . They didn't listen to him , but Richard Maskins sure did ..
Get away from that wall …
07-04-2020, 01:34 PM #1613
07-04-2020, 03:23 PM #1614
Watched this a while ago...he is a modest genius.
Lake X Kid liked this post
07-04-2020, 04:17 PM #1615
The Historic Photo Master
- Jan 2004
- Florida
- 38,725
- 78
- 1774
- 384
- 20479
- 4 Post(s)
Capt.Insane-o liked this post
07-04-2020, 04:26 PM #1616
- Jan 2004
- Florida
- 38,725
- 78
- 1774
- 384
- 20479
- 4 Post(s)
...again, very familiar with the porcupine/canted valve design chaz. i was in warranty for decades with these engines in ''stock" factory versions. too many warranty replacement units to count. i have hi-performance bbc experience as well, which is not what i was referencing.
07-04-2020, 05:04 PM #1617
Never got into big blocks even though they made them in my town of Tonawanda I believe it was called the Mark IV line, 50 years... no more.
I had a 64 Vette 327 with a few extra parts that would beat any big block around If I raced from a press, about died in it racing a new 440 Cuda this was 1971, going over a R/R crossing, while driving me to the Hospital the 440 6 pack Cuda owner could not believe he was getting beat by a 327, power to weight ratio and a motor that could breath real well.
Small blocks sing high notes
jLast edited by CUDA; 07-04-2020 at 05:10 PM.
07-04-2020, 05:12 PM #1618
5000 RPM
- Mar 2016
- cincinnati, ohio
- 695
- 151
- 36
- 287
- 205
Ok, who won, you or the Cuda??? And if you are a Chevy guy, why are you called Cuda???
j[/QUOTE]
07-04-2020, 05:52 PM #1619
- Jan 2004
- Florida
- 38,725
- 78
- 1774
- 384
- 20479
- 4 Post(s)
back in the late sixties/early seventies, the factory big block cars(no matter which one you choose of the big three) could not get any traction. for acceleration OR handling. those goodyear polyglas gt's didn't stand a chance, lol. or the firestone wide-ovals. they just sat there and sizzled.
07-04-2020, 06:39 PM #1620
8000 RPM
- Oct 2011
- Southern California
- 3,872
- 198
- 565
- 3529
- 2633
- 30 Post(s)
Interesting and sad photo
By Scream And Fly in forum The Scream And Fly LoungeReplies: 6Last Post: 09-27-2017, 03:49 PM -
Photos: *** Photo Contest Finalists!*** < Vote For Your Favorite Photo Here>
By Scream And Fly in forum General Boating DiscussionReplies: 36Last Post: 02-15-2013, 02:08 PM -
Photos: [photo contest] *** Post your BEST photo HERE, and there will be a winner ***
By Scream And Fly in forum General Boating DiscussionReplies: 146Last Post: 01-27-2013, 07:21 AM -
Body shop in 1920 - Interesting photo
By Scream And Fly in forum The Scream And Fly LoungeReplies: 20Last Post: 11-28-2009, 10:26 PM -
Classic Allison Photo #5 - VERY Early Race Photo
By Scream And Fly in forum General Boating DiscussionReplies: 22Last Post: 03-10-2006, 09:38 AM
