Results 1 to 14 of 14
Thread: Mercury 200 oil pump
06-15-2020, 08:13 PM #1
Member
- Jun 2020
- Toronto
- 63
On my 1991 Mercury 200 hp i'm having some issues with alarms going off. I've been trying to diagnose the oil pump as the issue. The input shaft spins while turning the powerhead showing the drive gear is still working as it should. I've spun up the oil pump using a drill with the actuator in the full throttle position and no oil comes out of the outlet side. Does the pump need the pressure of the small tank to actually get it to push oil?
06-15-2020, 09:56 PM #2
Not sure how to fix it but we will all tell you to ditch it. Mix your own oil at 50:1 under 6k rpm. 40:1 over that
06-16-2020, 06:47 AM #3
Member
- Jun 2020
- Toronto
- 63
Heading that way eventually but it's worked so well the last 8 years with no issues. At this point it's just curiosity trying to figure out what went wrong. THanks
06-16-2020, 10:34 AM #4
IF you are having any oil pump issues, DELETE the oil injection.
06-16-2020, 10:42 AM #5
06-16-2020, 01:28 PM #6
Member
- Jun 2020
- Toronto
- 63
That is what I saw at idle just a drip every now and then. When i pushed the actuator to full throttle and spun it again no oil came out at all. Ordered a new/used pump on ebay. Will try that for kicks and post back. Thanks
06-16-2020, 01:40 PM #7
Well, the alarm only sounds if the module doesn't sense the pump shaft turning or the oil is low in the reservoir... it doesn't know if oil is actually flowing into the motor so I doubt that's going to be your issue?
06-17-2020, 12:13 AM #8
There's a reason why a guy with almost 8000 posts and I are telling you to yank it. But hey, it's your motor......
sonicss33 liked this post
06-17-2020, 08:29 AM #9
Member
- Jun 2020
- Toronto
- 63
I appreciate the fact that allot of experienced individuals say delete the oil system. I'm running the boat on mixed oil and gas cans anyways now. I'm just curious what the problem may be. After i've thrown away some money on this then I will feel better about giving up. If and when I do give up how do I monitor engine temps without the alarm module in place? I have a water pressure gauge but it doesn't alarm to draw my attention when underway.
06-17-2020, 12:00 PM #10
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
as a long time Mercury V6 only motor rebuild shop it was not hard for me to sell the LOSE THE AUTO OILER to every customer i had because about 75/80% off all rebuilds i did were auto oiler fails so it was a no brainer
as for hot horn just about every motor came with one some were in the control box others were in the wire harness but had them none the less, if yours is not working i do recommend fixing it because you are right gauges become no issues and lull you into no observation stupor after a while you just dont look at them so a loud noise is required to snap us back to the surface they are on ebay most of the time but any 12 volt horn can be wired in GOOD LUCK
Dave Strong liked this post
06-17-2020, 06:44 PM #11
This may sound ghetto but I'm going to wire in a shift light or similar to my overheat alarm and mount it in my dash because I recently lost my external plumbing on my nosecone while runnING 70+ and only heard the damn alarm when I slowed down. Motor is OK but my nerves were shot at almost having toasted my beloved 200. And I'm also moving my water psi gauge to a better location.
TEXAS20225 liked this post
06-18-2020, 08:21 AM #12
Member
- Jun 2020
- Toronto
- 63
I was messing around with the oil pump again when I noticed fluid coming out of the oil pump shaft hole that goes into the block. This oily substance had the strong smell of gas in it. Would there be any reason for gas to be in this part of the block? I've been reading other sites and they mention some Delivery Check Valve that keeps gas from back flowing into the oil system from the fuel pump. Does anyone have any idea where this check valve may be? I've been looking at parts diagrams and can't see one either on the fuel pump or the oil pump systems.
06-18-2020, 06:14 PM #13
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
its on the bottom of the VST canister its the small L shaped fitting going back to mota with a little chicken squat vinyl hose on it
06-19-2020, 01:57 AM #14
Stock mercury single ram trim pump vs mercruiser style trim pump on a 2.5L
By Brookbbb in forum Technical DiscussionReplies: 2Last Post: 02-24-2017, 10:21 PM -
Rigging Accessories and Parts (Mercury Race Trim Pump, Fuel Pump, Steering, ETC)
By kcoleman10 in forum Misc. Parts and AccessoriesReplies: 7Last Post: 11-26-2013, 08:58 PM -
OLD MERCURY TRIM PUMP 1969 mercury 1000SS
By coreyh912 in forum Technical DiscussionReplies: 7Last Post: 07-05-2013, 11:31 AM
