Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 88 of 88
  1. #76
    Mar 2015
    DFW
    One of you fellas that is trying to help out mentioned "does your water pressure bounce on the gauge?" what is that an indicator of if it is?
    Bunger, brother... stay on topic man. You are all over the place worried about compression, plugs etc. Figure out your pressure issue and focus on one thing. Then worry about other crap. If you go messing with a bunch of other stuff all at the same time it is hard to determine anything.
  2. #77
    Aug 2005
    West Allis,Wisconsin
    Just resolved my high water pressure issue, was a bad dash gage.
  3. #78
    May 2017
    Ca
    That’s basically what I figured out. Gauge is super sensitive and I happened to get a super spunky new water pump. Boat runs great I’m sure the pressure will get back to normal once the pump wears in a bit
  4. #79
    I guess this would cause high pressure?
    Attached Thumbnails Attached Thumbnails 20200605_220734.jpg   20200605_220727.jpg
  5. Likes Dave Strong liked this post
  6. #80
    Quote Originally Posted by roadkill636 View Post
    Yup
  7. #81
    Jul 2004
    Connecticut
    What are those, wasp swampers?
  8. #82
    Rocks clogging 3 of the 4 dumps
  9. #83
    Jul 2004
    Connecticut
    What are the chances of 3 pebbles just the right size. Geez.
  10. #84
    Aug 2014
    WI
    OP...
    Did you ever resolve your pressure issue?
    Thanks
  11. #85
    May 2017
    Ca
    Quote Originally Posted by JAA View Post
    OP...
    Thanks
    negative. I ran it that way for a whole summer and sold the motor and upgraded to a 250pro xs
  12. #86
    Aug 2014
    WI
    Quote Originally Posted by Bunger View Post
    hahaha dang... Im pulling my powerhead saturday in hope of finding some pebbles. Thanks for the reply
  13. #87
    Apr 2023
    Long island, NY
    I pulled the powerhead on a 150 I bought to change the midsection. I was very surprised to find this. Motor ran perfect. No pressure or temperature problems. But I did have to unclog the telltale twice.
  14. #88
    May 2001
    Maine
    Probably something to definitely check if you buy a used motor and the paint is worn off the skeg and bullet... potentially a lot of beaching as rocks & gravel don't usually float.
  1. High Water Pressure After Changng Water Pump
    By maineidyl in forum Technical Discussion
    Last Post: 08-11-2018, 05:10 PM
  2. Mercury Tech: High water pressure & low water temp
    By njj502 in forum Technical Discussion
    Last Post: 10-19-2017, 03:00 PM
  3. promax high water pressure
    By ActivatedSludge in forum Technical Discussion
    Last Post: 10-25-2014, 08:06 PM
  4. Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
    By sasquitch in forum Technical Discussion
    Last Post: 07-31-2010, 09:16 PM
  5. 2000 Promax High Water Pressure Issue
    By Big E in forum Technical Discussion
    Last Post: 11-09-2009, 04:13 PM
