Results 16 to 30 of 36
    Jul 2005
    AZ
    Still curious if you have access to another compression gauge?
  2. Thanks bimmer1 thanked for this post
    Likes bimmer1 liked this post
  3. #17
    Karrebaeksminde, Denmark
    Good idea swabbing the boxes. I´ll try that.
    I think I do have a DVA meter (see picture), can I use that?
    I must admit that I feel more confident when it comes to mechanical issues (internals, carbs, etc), than electirical issues but I will do my best to learn from this.
    My meter:
    What must I measure with the Multi meter to find the cause of this issue?
    Bimmer1
  4. #18
    The pressure gauge I have is to be honest a cheap one. I will try a source a better one.
    By the way. Best practice when measuring compression? Hot/cold? Open throttle or closed?
    Bimmer1
  5. #19
    Quote Originally Posted by bimmer1 View Post
    My meter:
    Bimmer1
    Thats just a multi meter, can use to measure resistance but not to measure peak running voltage.
  6. Thanks bimmer1 thanked for this post
  7. #20
    Bimmer1
    I do it cold, throtle opening never seems to make much difference. Whatever way you do it always do it the same way.
  8. Thanks bimmer1 thanked for this post
  9. #21
    Jul 2005
    AZ
    Since checking against what you got before (100psi)
    Like Dave said do it the same way you did before..
    And other then cranking it over alot more it's usually not that much different+-...unless you have something wrong.
    Oh but don't check with extra oil etc like in spring w fogging oil.. only mention because just had someone do that...
  10. Thanks bimmer1 thanked for this post
  11. #22
    Houston, TX
    Yank all spark plugs, peg the throttle, screw in the gauge, and give her a whirl.
  12. Thanks bimmer1 thanked for this post
  13. #23
    Houston, TX
    Forgot to add...hook spark plug wires to tester or put spark plugs in the wire boots and ground the bodies of the plugs.
  14. Thanks bimmer1 thanked for this post
  15. #24
    Swabbing the Switch boxes didn´t get me any further since the left bank is still not firring. I guess the stator is the next step and since I have another V6 merc that I´m using for parts, I´ll try taking the stator from the part engine and move it to the V200.
    Speaking of the engine for parts. Maybe some of you guys can help me here. The serial (on the mid) is 5531531 on the part engine.
    The cowl says 225 and it has a choke plate with shutters that are operated by a small motor. When checking the serial online I get nothing. Any ideas?
    Bimmer1
  16. #25
    Sep 2017
    Ashland city tn
    1st I've never seen stator kill 1 bank. Possible I guess but I dont think so , trigger yes , so u swapped boxes around and was same ?
  17. Thanks bimmer1 thanked for this post
  18. #26
    Sep 2017
    Ashland city tn
    Also try add a "0" at beginning of serial when u type it in
  19. Thanks bimmer1 thanked for this post
  20. #27
    I also think it´s highly unlikely since the stator is only 2 years old. I doubt it is the Ignition coils, what are the odds of 3 of them failing at the same time.
  21. #28
    Stator
  22. Thanks bimmer1 thanked for this post
  23. #29
    Is there a way to tell if it is the stator or not without replacing it? Can I visualy or my measuring somthing tell if the stator is the bad guy here? I will remove the flywheel asap to check if something obvious can be seen.
    Bimmer1
  24. #30
    Bimmer1
    DVA is best but can do ohm tests as per manual.
  25. Thanks bimmer1 thanked for this post
  1. Mercury 200xri Rough In-Gear Idle
    By Hess in forum Technical Discussion
    Last Post: 05-29-2019, 10:49 PM
  2. Low / rough idle in gear
    By Blown Up in forum Technical Discussion
    Last Post: 07-27-2012, 03:10 PM
  3. 1973 evinrude 85 is running rough at idle speed in gear.
    By Palmtreeguy in forum Technical Discussion
    Last Post: 06-06-2012, 12:40 AM
  4. OMC Tech: OMC rough idle when dropped in gear
    By LSaupe in forum Technical Discussion
    Last Post: 06-20-2009, 09:43 AM
  5. Merc V200 Crappy Idle
    By pop_r_master in forum Technical Discussion
    Last Post: 04-27-2005, 10:49 AM
