				Results 481 to 495 of 496
		Thread: 13' Bullet 130 Rebuild & Repower
	04-05-2020, 11:57 AM #481
	04-05-2020, 01:14 PM #482
Here's a few shots, boat needs to be setup, but happy for first splash, got 52 at 5300 rpm, got 1000 to gain and plenty of water pressure, needs to come up and the tunnel boat prop has no cupping and its big so that dont help.. ill take it for the first run, need to get used to the boat also find what it likes.
				tnelsmn liked this post
	04-05-2020, 02:44 PM #483
	04-05-2020, 02:55 PM #484
	04-05-2020, 07:42 PM #485
						Member
 - Mar 2018
 - Laval, Quebec, Canada
 - 43
 - 234
 - 24
Thumb up Keep posting as you improve your setup. 2-3 vids would be great.
				TwzteD liked this post
	04-07-2020, 12:31 PM #486
Not the best video but it's something from the first run, working on setup now. The fun part.
	04-07-2020, 11:41 PM #487
Love the flag on the transom!
	04-08-2020, 07:22 AM #488
	04-28-2020, 06:00 AM #489
Still working on figuring setup out, got a few videos up of it in case you wanted to take a look, still not 100% where i want it but gaining little by little every time i go out.
	04-28-2020, 07:09 AM #490
Looks like you got it running pretty good. I wouldn’t go any higher if you’re going to continue to run at high speed. The stream from the pisser is very week. Try plugging the top 2 or 3 holes. Nice Job
13' Bullet 60 Merc
	04-28-2020, 07:09 AM #491
						Member
 - Mar 2018
 - 43
 - 234
 - 24
Did you improve your top speed?
	04-28-2020, 07:22 AM #492
It's In spec, I have a water pressure guage and smartcraft, was runing from 120-130°. I'm going to be adding scoops to the gear case to see if it helps I had plenty of water pressure until I start trimming a little past neutral so with the scoops it should be perfect, that's as high as I can go without running a jack plate It's bolted straight to the transom so I'm going to see what kind of performance I can get out of it like this. Now that I know I have enough water pressure and adding scoops will likely boost it a lot because if you look there's still a lot of water shooting up from the bullet right past the the inlets so the scoops will catch a lot of that water. The problem is all of my props are too big I'm still about a thousand RPM short, The only prop that has reached the limiter is 11x18 regular cleaver but that was bouncing off the rev limiter at 6250 RPM all of my props including the one in this video are around 5,200 RPM, I did however throw my four blade cleaver back on and picked up a few miles an hour by raising the engine a few holes since the last time I tested it. Every time I go out I gain a little bit nothing crazy Still have to work on figuring out what kind of props this boat likes I have only tried cleavers and semi cleavers so far So I'm going to be borrowing a chopper from someone to see that maybe the ticket The boat does need a little bow lift so we'll see.
				89LASER liked this post
	04-28-2020, 07:24 AM #493
Yea 55.5 mph right now but still 1000 RPM to low.
				LMT383 liked this post
	04-28-2020, 10:40 AM #494
	09-05-2020, 12:40 PM #495
New things to come the formula race was sold, SST60 power to be implemented.
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
