Page 16 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 LastLast
Results 226 to 240 of 444
  1. #226
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by Dave Strong View Post
    Should be a plug to let them drain, not sure on a 23.
    Hi Dave,
    There is a plug in the back on all three hulls but if I reach back through the screw-on cover under the seat there is a bulkhead with no drain hole. Water gets trapped in that area and can't get out of the plug hole in the back. I should have taken pictures but the boat is 5 hours away now. Both my Baker and Lavey had three bilge pumps. The Cougar only has one in the middle. Hopefully someone witjh a 23 will post a picture of under and behind the rear seat so I can see if mine is the same.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  2. #227
    Quote Originally Posted by luv2gofast View Post
    Hi Dave,
    Strange, not been inside a 23 before, they were pretty good about making sure the hull could be completely drained. Have seen smaller plugs used to drain water so all could run out the back. Type like a 10 or 12 aluminum boat hull plug.
  3. #228
    May 2013
    Brockville, ON Canada
ID:	463558This year I update my Cougar 22 MTR with a 300R, I had it wrapped white and then had custom reflective decals made for it
    Attached Thumbnails Attached Thumbnails 5FEB8FEC-7A19-4F3D-A815-5DEF829C2D5D.jpeg
  4. Likes AZMIDLYF, Speedicat liked this post
  5. #229
    Aylesford Lake,NS Can.
    Let's See Your Cougars-Boats That Is!!!
    Quote Originally Posted by Johnny Five View Post
    Johnny Five
    Nice looking 22MTR. How does it run with the 300R? Do you have any before pictures? Where did it come from? We need more details, post them up. Welcome to the board.
    Thanks
    Gary
  6. Likes RvrDave liked this post
  7. #230
  8. Likes whipper, Speedicat liked this post
  9. #231
    May 2013
    I posted in this thread way back on page 7 I bought my ‘04 Cougar from a guy in Ottawa Ontario 4 years ago. He bought it from a guy in Toronto. The 300XS was installed by Boomer (Alex) while he worked at Top Gun Marine. The 300XS barely got this Cougar to 93mph, once! (Tall prop, useless unless I was alone, little fuel Typically With two in the boat, I’d run 88. I only have one test blast with the 300R, I hit 86 with a Dewald 4 blade 30x15
    Attached Thumbnails Attached Thumbnails ED15ECEB-0B75-4CD9-B596-0D98850CC79F.jpeg
  10. Likes whipper liked this post
  11. #232
    Mar 2015
    Ventura Co
    Johnny Five, keep us posted! I have a 22MTR with a 300xs and thinking about a 300R.
    How do you like the overall driveability difference between the two engines? Low end torque? MPG? Etc...
  12. #233
    May 2013
    Yesterday I tested a 32 pitch Bravo 1 and hit 95 mph, which is the fastest I’ve ever had this boat. I’m absolutely loving the torque of the 300R, it jumps on plane so easily! The 300XS I had previously laboured to get on plane. I used to “try” to run a Dewald 4 blade 30 pitch and the 300XS couldn’t get it past 5300 rpm, this 300R will take that same prop right to 6450!
    Attached Thumbnails Attached Thumbnails AACC0FCA-FAA9-4561-8998-545671C96A0E.jpg
  13. Likes AZMIDLYF, Speedicat liked this post
  14. #234
    May 2013
ID:	466272Click image for larger version.
ID:	466273Click image for larger version.
  15. Likes whipper, Speedicat liked this post
  16. #235
    May 2013
    I found the “best” place to drill a 6” hole in the floor right behind my rear seat (I will install a water tight deck plate) so that I could drill a 1” hole into the cavity in front of the rear-most cavity. I will also be adding sponson drains via brass threaded fittings. This way I can ensure there’s no water under my floor (it was full when I bought the boat). I also drilled a hole under the front seats so that I could suck the water out if that “compartment”. Then I went under my deck and through the little door at my kickolate and then drilled through the front of the front “compartment” (so that I can suck water out of the front compartments (turns out they were dry). I hope this makes sense. Ask questions if necessary.Click image for larger version.
  17. #236
    Nov 2003
    Simi Valley, SoCal
    Yes totally makes sense and I am having the same problem. I have 3 deck plates under my back seat, one for each sponson and one for the pod. I have drain plugs in all three spots in the rear but without cutting the floor out I have no idea where or how many compartments there are. I am getting water in the starboard sponson and can't find any way for it to get in. I have tried filling it with water while on the trailer and not a drip anywhere. Click image for larger version.
ID:	466294Click image for larger version.
ID:	466295Click image for larger version.
  18. #237
    May 2013
    Water under floor needs to go!
    there are 4 compartments in each sponson (in my boat anyway). I found most of my leaks were from my rub rail, so I removed it and resealed the joint and rivet holes.. I have pictures (of another Cougar 22 MTR, not mine) with the floor cut out. Shoot me a PM if you’d like to see under your floor. For me...I just found places to drill a 3/4” hole in inconspicuous places so I could suck out the water.
  19. #238
    May 2013
    here’s a little video I just made to explain how I am dealing with water under my floor.
    https://youtu.be/jfTKKOGxiTw
  20. #239
    Nov 2003
    Simi Valley, SoCal
    I think mine's made about the same. I'll drill some holes and see if I can find any more trapped water. Thanks for the video!!
  21. Likes Johnny Five liked this post
  22. #240
    May 2013
    The other truck I used was after I drilled the small 3/4” hole, I would bend a coat hanger in a 90° bend and start with a 6” tail, I’d turn it while inside the hole and try to find the next bulkhead. If it doesn’t reach, make the tail longer. That will help you get a mental image of what is under your floor, and help you decide where to drill the next small hole. Then I used a Flo N Go to suck the water out. I also used a scope camera to have a look inside.
  1. How many guy's on here have 2004-2005 boats or have older boats ??
    By LPB in forum General Boating Discussion
    Last Post: 01-13-2018, 06:09 PM
  2. New mini performance boats? - St. Martin Power Boats
    By jonnyspeed in forum General Boating Discussion
    Last Post: 04-09-2009, 08:30 PM
  3. Bass and Walleye Boats Mag...Triton boats!
    By Mr.Rude in forum General Boating Discussion
    Last Post: 06-06-2006, 10:13 PM
  4. Triad Boats and STV Custom Race Boats
    By Dinomite in forum General Boating Discussion
    Last Post: 12-27-2003, 10:30 AM
