Results 1 to 15 of 25
03-09-2020, 05:54 PM #1
"Right Stuff" and other sealants in place of gaskets??????
So there are a lot of BADa$$ sealants/adhesives on the market now. Black, gray, red, Right Stuff, etc. I have my powerhead off and about to be the adapter, too. Has anyone put these back together with adhesive/gasket maker instead of the big precut gaskets? Would be a bit of a pain to take back apart but this stuff sure works well in automotive applications.
Thoughts? Why or why not?1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
03-09-2020, 10:03 PM #2
No opinions on S&F??? I'm shocked!
03-09-2020, 10:31 PM #3
Only gasket issues I’ve had has been at the exhaust port area on the power head gasket (9 times out ten find the adaptor to have a low spot in that area because of the temp differences). I always use the gaskets, if I’m dealing with the large rectangular exhaust ports I use the hi-po powerhead gasket that has the infused metal. If on the small square port, I will usually put a thin coat of ultra-copper around the exhaust port area on both sides of the gasket. I use the ultra-copper because of how well it performs in high heat situations.
Last edited by FORBESAUTO; 03-10-2020 at 03:25 PM. Reason: Left out heat on high heat
rgsauger thanked for this post
XstreamVking liked this post
03-09-2020, 11:09 PM #4
Thanks Forbes. this is a V200 carb motor, 2.4
03-10-2020, 03:10 PM #5
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
Ultra or Right Stuff is good insurance.
Gary
03-10-2020, 03:36 PM #6
Rite stuff is bad chit , just use a thin layer so the plates squeeze together and clamp down on top mounts correct , to much will leave a gap
03-10-2020, 08:37 PM #7
03-10-2020, 08:39 PM #8
03-10-2020, 08:39 PM #9
I use gaskets only but if I think it could leak I'll use thin thin layer over gasket ,
03-10-2020, 08:45 PM #10
Hey Merc, do you run the Cumberland for brown fish or do you ever get into the walleye and sauger? I used to catch a bunch below old hickory dam when I lived there.
03-10-2020, 09:26 PM #11
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
"You saying in addition to gaskets? "
Yes but very sparingly. Just a thin layer like a coat of paint. If using in place of a gasket...very clean surfaces and a small bead...just enough to barely squeeze out. Never close to a water or oil passage way(Hole). This is what has worked for me use at your own discretion. Just like the Brylcreem jingle "Just a little dab will do ya, use more only if you dare!"
On my water pump gaskets this is what happens if I don't use the sealant as a glue to keep them intact(both sides).
Gary
03-11-2020, 06:17 AM #12
rgsauger liked this post
03-11-2020, 07:16 AM #13
Screaming And Flying!
- 15,059
- 407
- 1450
- 6007
- 11666
I have used the permatex blue gasket dressing on lots of stuff. I use the copper permatex around the exhaust area also. Sealants can only help if used sparingly. Dressing allows things like t-stat gaskets to be removed and reused over and over.
03-11-2020, 07:59 AM #14
Copper and aluminum do not play well together. Steel like in a car/truck block it works very well....my .2
Whaaaaat thanked for this post
03-11-2020, 10:32 AM #15
5000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
I never use ultra copper on anything aluminum that might see salt. Even if called for in service manual. It corrodes the aluminum. Use the right gaskets, If surface is questionable i like aviation form a gasket coated on the gasket. It's like brown tar. Never really hardens, stays sticky.
kellytheaker thanked for this post
tux974 liked this post
OK, old school D/B Motocross riders, "strut yer stuff!" Pix/stories
By Robby321 in forum Other MotorsportsReplies: 3Last Post: 03-10-2020, 03:16 PM -
Mercury Tech: '87 2.0 150 no carb or fuel pump kits? gaskets and bleed check valves "obsolete"?
By pcrussell50 in forum Technical DiscussionReplies: 2Last Post: 08-23-2016, 12:51 PM -
HA!..Whats the weirdest place, ya ever "got some"..
By Robby321 in forum The Scream And Fly LoungeReplies: 53Last Post: 05-04-2010, 12:14 AM
