Results 1 to 12 of 12
Thread: HELP HELP with Sportmaster !!!
03-01-2020, 08:13 PM #1
Hi SF Techs,
I bought a tunnel with twin CLE lowers and when I open find out the prop shafts and drive shafts were dead, corrosion all over (see pics). I need to replace but don't know for sure the parts numbers since they are old Racing Engines. (They came off 1998 Mercs 260HP EFI Offshore 20”).
Appreciate any HELP.
RALast edited by rarias; 03-02-2020 at 10:44 AM.
03-01-2020, 10:52 PM #2
They are cle lowers,and salty ones at that.imo id replace them.
tux974 liked this post
03-01-2020, 11:01 PM #3
All toast salt never any good except on steak
03-01-2020, 11:06 PM #4
03-01-2020, 11:10 PM #5
What is the difference between cle and sportmasters ? Any part #s
03-01-2020, 11:13 PM #6
Yup. Defiantly not SportMaster. Thoes are 4 hole small shaft CLE lowers
03-01-2020, 11:26 PM #7
If ya can get em apart haha id hate to see what the guts look like.Says your in Miami and those babies have been living there along time.
03-02-2020, 12:47 AM #8
03-02-2020, 02:40 AM #9
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
just put a used D/S in it the prop looks ok.....steel shafts rust but are stronger than ss.....bet my 5 cents of nik on it.....
03-02-2020, 06:54 AM #10
5000 RPM
- Aug 2006
- virginia
- 848
- 45
- 154
- 549
- 1128
ive had great sucess installing speedy sleves on junk drive shafts. also can be installed on prop shafts before installing prop shaft seals.
https://www.screamandfly.com/showthr...uot-driveshaftLast edited by SUNKIST; 03-02-2020 at 06:57 AM.
03-02-2020, 09:37 AM #11
I did not have luck on speedy sleeve burned the seal out in couple hrs because of added circumference maybe ok if lower submerged ,but surfacing ?
03-02-2020, 10:51 AM #12
Had no idea they were CLE, thanks.
The internal parts for some reason were ok but changed all for new parts. Got both prop shaft (small). Now the hard part, the drive shafts. Not sure if the sleeve is the way, corrosion is very advanced, this boat had been sitting inside a hangar for 10 years imagine that...
Were the steaks I got the sae salt LOL
Regards,Last edited by rarias; 03-02-2020 at 04:55 PM.
Anyone looking to trade a 1.75 sportmaster for a 1.62 sportmaster?
By 2.5-21 in forum Lower UnitsReplies: 0Last Post: 10-02-2018, 07:25 AM -
250R 300R Sportmaster vs 3.0 Sportmaster
By xb03fs in forum General Boating DiscussionReplies: 21Last Post: 07-13-2018, 06:54 AM
