Results 151 to 165 of 273
Thread: 300r vs 300xs on same boat
02-13-2020, 11:43 PM #151
Have you ever used a 3/4" impact gun, or torque wrench ??? Drive shaft "splines" is a square drive.
The "black washer" is a timken style bearing, the race behind it the thrust face, just as the back of the "ring gear" is.
All three propshaft bearings have a groove on the outer race to locate it. And the back two have a thrust collar between them.
Straight cut gearset is at least a 12 DP .. you can rest assured it's either 8620 or 9310 carburized steel.
Chaz = thinkin, you won't break one anytime soon ...
02-14-2020, 12:40 AM #1521980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
02-14-2020, 12:59 AM #153
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,388
- 1083
- 423
- 4808
- 2211
- 9 Post(s)
Looks way easier to setup than an sst45 that doesnt split
Instigator liked this post
02-14-2020, 08:13 AM #154
I’ve always loved the hot rod V-6 stuff butttttt, when I went to my first kneel down race in the ‘70’s, and saw my first, true, “Pro/Alky” class motor..., it all changed.
Four cylinder, horizontally opposed, two (or four) expansion chambers, on slides to adjust their “tuned length”, real race gear cases, 6” mid sections, rope start, methanol fuel and castor oil, so much compression that each crew had A guy to “rope the motors”, so high strung that you needed two more crew members to hold the back of the boat out of the water so you could rope the motor, 10K+ RPM, rotary valves, weighed 65 lbs, and the 500cc’s are now close to 200 HP’s, and they came from the factory that way........I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
Capt.Insane-o liked this post
02-14-2020, 08:55 AM #155
02-14-2020, 09:43 AM #156
02-14-2020, 09:51 AM #157
powerabout liked this post
02-14-2020, 10:15 AM #158
02-14-2020, 10:54 AM #159
02-14-2020, 12:51 PM #160
https://www.haltech.com/how-flex-fuel-control-works/
This might shine some light how they do it in the aftermarket world. I have not looked into the 300R to know if it is a DI or Port injection motor. But the VE tuning and flex fuel is pretty much standard in the aftermarket car world.
Just a little Cat.
24 Twister V8 E-Rude (For Sale)
2008 Concept Sport Deck 2x 300X
02-14-2020, 03:04 PM #161
There’s a thread on OSO showing a notice from Merc warning that A., they will be checking computers for manipulation and will cx warranties accordingly and that B., the EPA is also watching and they have already nabbed a few.
02-14-2020, 06:22 PM #162
02-14-2020, 06:58 PM #163
300+ on 87 octane...I would leave the damn thing alone. What it needs is to be five inches shorter.
02-14-2020, 07:14 PM #164
6000 RPM
- Oct 2009
- Gonzales, La
- 1,086
- 114
- 69
- 219
- 355
02-15-2020, 11:20 PM #165disc's
From crickets to corn E-98, E-85, E-10, M-1 wood, 87, 93, C-16, Q-16, NOSMAX120, and CH3N2O .. since it's Mercury ... All those tunes will be on compactavailable from Mercury racing direct, or Wal-Mart'smuz-aksection.. just plug one in the stereo. Or for the ballers, load up a CD changer full of cartoons ...<strike></strike>
Fastbass Marine TV - Mercury Racing 300XS vs 300R
By river rocket in forum General Boating DiscussionReplies: 5Last Post: 10-22-2019, 08:32 AM -
Part # For boat side harness for 300R
By aggiestckl in forum Technical DiscussionReplies: 2Last Post: 08-18-2019, 12:46 PM -
Actual comparison Videos comparing the Mercury 300XS and 300R on 21 Liberators
By WILDMAN in forum General Boating DiscussionReplies: 24Last Post: 12-26-2018, 09:32 AM -
2007 liberator 21 300xs 190hrs rare solid red boat freshwater boat
By Mercaholic86 in forum Hulls larger than 20'Replies: 4Last Post: 10-31-2018, 01:44 PM
