Page 11 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 151 to 165 of 273
  1. #151
    thats hanging onto 200? hp but how much torque?
    Have you ever used a 3/4" impact gun, or torque wrench ??? Drive shaft "splines" is a square drive.
    The "black washer" is a timken style bearing, the race behind it the thrust face, just as the back of the "ring gear" is.
    All three propshaft bearings have a groove on the outer race to locate it. And the back two have a thrust collar between them.
    Straight cut gearset is at least a 12 DP .. you can rest assured it's either 8620 or 9310 carburized steel.
    Chaz = thinkin, you won't break one anytime soon ...
  2. #152
    Dave thinks impact stuff has no place on engines, just saying. The special rattle is best left to those who do not understand.
  3. #153
    Looks way easier to setup than an sst45 that doesnt split
  4. Likes Instigator liked this post
  5. #154
    12 Post(s)
    I’ve always loved the hot rod V-6 stuff butttttt, when I went to my first kneel down race in the ‘70’s, and saw my first, true, “Pro/Alky” class motor..., it all changed.
    Four cylinder, horizontally opposed, two (or four) expansion chambers, on slides to adjust their “tuned length”, real race gear cases, 6” mid sections, rope start, methanol fuel and castor oil, so much compression that each crew had A guy to “rope the motors”, so high strung that you needed two more crew members to hold the back of the boat out of the water so you could rope the motor, 10K+ RPM, rotary valves, weighed 65 lbs, and the 500cc’s are now close to 200 HP’s, and they came from the factory that way........
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  6. Likes Capt.Insane-o liked this post
  7. #155
    Quote Originally Posted by Dave Strong View Post
    750 ft/lbs / 1200 break away . Perfect for 1/4x20 or 6x1.0mm bolts ..
    I had to make sure that guy didn't borrow my "hi-grunt" 90* ...
  8. Likes Dave Strong, powerabout liked this post
  9. #156
    The 300r will make 400 naturally aspirated once someone does a 93 octane tune for them.
  10. #157
    May 2009
    Ormond Beach, Florida
    Make it like many of the car tunes where I can select the tune based on the quality of fuel available and I'm all in but I doubt the ECM is capable of that.
    Mark
  11. Likes powerabout liked this post
  12. #158
ID:	458633Click image for larger version.
  13. Likes Instigator liked this post
  14. #159
    Quote Originally Posted by mjw930 View Post
    the new flex fuel cars and trucks have alcohol sensors in the fuel system and adjust accordingly for it. That would be nice but I’m guessing you’d have to tune it to the fuel you run.
  15. #160
    Sep 2007
    Saginaw, MI
    https://www.haltech.com/how-flex-fuel-control-works/
    This might shine some light how they do it in the aftermarket world. I have not looked into the 300R to know if it is a DI or Port injection motor. But the VE tuning and flex fuel is pretty much standard in the aftermarket car world.
    http://i35.tinypic.com/epn6ma.jpg
    Just a little Cat.
    24 Twister V8 E-Rude (For Sale)
    2008 Concept Sport Deck 2x 300X
  16. #161
    12 Post(s)
    There’s a thread on OSO showing a notice from Merc warning that A., they will be checking computers for manipulation and will cx warranties accordingly and that B., the EPA is also watching and they have already nabbed a few.
  17. #162
    100 HP in a type~a~writer ...
    Why ya wanna tease the Merc bouyyyyssss ...
    Hey .. can ya flash a set of these 10:0 /1's in , while I wait ...
  18. Likes powerabout liked this post
  19. #163
    300+ on 87 octane...I would leave the damn thing alone. What it needs is to be five inches shorter.
  20. Likes Instigator liked this post
  21. #164
    Oct 2009
    Gonzales, La
    From crickets to corn E-98, E-85, E-10, M-1 wood, 87, 93, C-16, Q-16, NOSMAX120, and CH3N2O .. since it's Mercury ... All those tunes will be on compact
    disc's
    available from Mercury racing direct, or Wal-Mart's
    muz-ak
    section.. just plug one in the stereo. Or for the ballers, load up a CD changer full of cartoons ...
    <strike></strike>
  23. Likes powerabout liked this post
  1. Fastbass Marine TV - Mercury Racing 300XS vs 300R
    By river rocket in forum General Boating Discussion
    Last Post: 10-22-2019, 08:32 AM
  2. Part # For boat side harness for 300R
    By aggiestckl in forum Technical Discussion
    Last Post: 08-18-2019, 12:46 PM
  3. Replies: 24
    Last Post: 12-26-2018, 09:32 AM
  4. 2007 liberator 21 300xs 190hrs rare solid red boat freshwater boat
    By Mercaholic86 in forum Hulls larger than 20'
    Last Post: 10-31-2018, 01:44 PM
