Results 16 to 30 of 31
Thread: How F'd is my crank
02-05-2020, 12:42 PM #16
The Historic Photo Master
- Jan 2004
- Florida
- 38,613
- 78
- 1787
- 385
- 20587
- 5 Post(s)
this is the bottom line with 2 stroke cranks... they have to be perfect. the end.
02-05-2020, 03:10 PM #17
Call BLACKBIRD . he'll buy it
02-05-2020, 03:38 PM #18
roadkill636 liked this post
02-05-2020, 04:31 PM #19
Ask David Eden if he can fix it. If he says no, it is a no.
stoker2001 liked this post
02-05-2020, 04:58 PM #20
That is (supposedly) the one place- Marine Crankshaft in CA- repairing them "properly": http://www.marinecrankshaftinc.com/outboard.html
02-05-2020, 05:55 PM #21
Screaming And Flying!
- Dec 2001
- 9,487
- 271
- 191
- 1979
Why bother fixing.....A good used one is $200....end of story.....I don't see any Lancia V6 cranks as lamps....They were art work....... 5cly audi?
02-05-2020, 06:01 PM #22
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
You’d be 500 into it for Marine Crankshaft to fix and it’ll still be a repaired crank. Just find another one. That one is junk
Erik Kiser
02-05-2020, 07:37 PM #23
I have a crank that 1 journal has damage but its barely enuff to catch finger nail , I figured its junk , but r u sayin if it's a very minor nick or sumthin it could possibly b fixed? Just curious,
02-05-2020, 07:40 PM #24
02-06-2020, 12:47 AM #25
- Dec 2001
- 9,487
- 271
- 191
- 1979
Merc 2.5.....a small nick is ok.... for a fissing or hand granade.....If ya use the old Big rods it will hold up case's them rods are close to bullet proof.....but stick a piston and they will beat a block to bits.....Yes.I have rods........Sorry I never got back to you about carbs......that happens in Daves world........
02-06-2020, 05:33 AM #26
Forget fixing! Find another crank and make that one a nice lamp with custom bearing surface!......
Also as stated, check your oiling check valves are working properly and clean.
TEXAS20225 liked this post
02-06-2020, 11:44 AM #27
02-08-2020, 11:09 AM #28
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
x2 Tony i have a clear hose i put on the bottom to top bearing oiling hose to see if its oiling then replace it with new stuff, rods are just as dangerous if that cap aint perfect i never used it i ve seen many rod bearings that cage hung on the mismatch and bearing started skidding ruining crank and soon the rest of the assembly
02-09-2020, 01:29 AM #29
- Dec 2001
- 9,487
- 271
- 191
- 1979
To the orgg poster.... I have a crank if ya want.... u pay shippin.... to 2.5 merc.... same as I have rods just PM me ya # street adds...good lukanhappynewyears......and ck the flwhell... top brng.....something ate the bearing.... pre 1982s bulestrip....have poor contact area... on the lower seals.. JUSTWHATIKNOW....I know Dave S. is a ****ty spella...Hick......
02-09-2020, 05:45 AM #30
Amen Bobby! I use yellow Tygon with small tie wraps on all bleed. I also always replace the top & bottom bearing plus cap seals top& bottom no matter how good they may look.
New Big bearing 2.5 crank (not a 260 style crank)
By GILMORE010 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 02-24-2016, 03:32 PM -
drag crank,has a coller or spacer between bearing and crank is this normal?????
By camaro7081 in forum Technical DiscussionReplies: 29Last Post: 10-22-2009, 09:42 PM -
what is the difference from a 260 crank to a fishing motor crank
By camaro7081 in forum Technical DiscussionReplies: 21Last Post: 02-14-2007, 08:20 PM -
Top Main Crank Bearing/ Rod To Crank Bearings
By mr twister in forum Technical DiscussionReplies: 2Last Post: 09-09-2003, 08:45 AM
