Results 106 to 114 of 114
Thread: Stuck Prop
01-19-2020, 09:48 AM #106
Now what's your plans with the lower unit? Gunna replace anything? Carrier? Propshaft seals? Etc?
01-19-2020, 10:17 AM #107
5000 RPM
- Oct 2008
- Plainville, CT
- 864
- 471
- 30
- 438
- 76
01-19-2020, 10:21 AM #108
5000 RPM
- Oct 2008
- Plainville, CT
- 864
- 471
- 30
- 438
- 76
08-23-2020, 09:21 PM #109
5000 RPM
- Aug 2002
- Kansas City
- 524
Don't know what I was doing wrong before; maybe it was not enough lubricant for the operator... I got the puller on straight, greased up the bolt and tightened it down so hard that I was afraid I was going to break something. Nothing. PB Blaster on it. Hit it with a hammer. Put a blanket over it just in case something broke when I was tightening. it's sitting with the splines up so it will hold the PB on the splines. Will check it out next week. Maybe put an impact on it or a breaker bar instead of the big crescent wrench.
08-23-2020, 09:37 PM #110
08-31-2020, 08:25 AM #111
5000 RPM
- Aug 2002
- Kansas City
- 524
Was tightening up the bolt this weekend and heard a pop. Thought the prop had come loose... Nope, the weld on one of the chain links broke. Time to get some better chain. Using a crescent wrench on it and didn't really think I was tightening it that much. No wonder the Proptopus company is out of business.
08-31-2020, 09:03 AM #112
The Historic Photo Master
- Jan 2004
- Florida
- 38,703
- 78
- 1772
- 384
- 20444
- 4 Post(s)
...there's a lesson here i think...& its not about how to remove a propeller...
08-31-2020, 04:53 PM #113
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
Ya..... had a good puller...Broke a good 1/2 breaker bar..... blanket just in case......nothing.... left it for weeks....A guy gave me some new? stuff called Creeps…. will try that.... I did not put these props on...….
09-03-2020, 02:41 PM #114
I have a 20 ton Harbor Freight hydraulic floor press that has 3 settings, 1. Disassemble 2. Assemble 3. Break Something.
Mostly I have ended up with setting #3
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
SS prop stuck on a V4 OMC gearcase
By Sparkieboat in forum Props, Setup, and RiggingReplies: 9Last Post: 06-21-2015, 03:01 PM -
Removing prop stuck on shaft
By twright55 in forum Props, Setup, and RiggingReplies: 10Last Post: 07-19-2010, 08:28 PM -
prop stuck on the shaft
By rdkvector in forum Technical DiscussionReplies: 8Last Post: 05-08-2010, 12:57 PM -
Removing stuck prop
By riverrat321 in forum Technical DiscussionReplies: 10Last Post: 06-27-2007, 06:06 PM -
What is the best way to get a stuck prop off?
By PFord in forum Technical DiscussionReplies: 9Last Post: 10-19-2004, 02:04 PM
