Page 6 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 114
Thread: Stuck Prop
  1. #76
    Feb 2014
    Missouri
    High carbon stainless is very hard up to 65r my custom knives are cryo to 62-63r
    usa requires 13% or more Crome to be called stainless.
    Chepstainless is often a sainma (sp?) type (basically electoplated but not) bust through it and regular steel inside rust.
    More on point though is the shaft is galled as you say or corroded and shot anyway. So cut or pull a new shaft will be needed.
  2. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  3. #77
    Well, nowhere did I say it's galled, hell it's not even mine! Said possible to get galling on pulling it with hydraulic puller. Also most shafts are 316 (guess there). I was simple trying to tell about galling and SS. You can go a thousand pages discussion the properties of all steel, as what other elements added. And besides, why cut the shaft when you can cut the prop off and see if it's still good. And we aint talking knifes here but a motor prop shaft.
  4. #78
    JAX. FLORIDA
    I have moved-the-immovable with a combo of ATF/Acetone, Ottawa hydraulic puller and an air hammer/chisel. Using all of them together along with patience has always worked for me.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  5. #79
    Little more. (Also I'm retired 26 years, so forgot more remembered.)
    Prop shafts..
    Others uses
  6. Thanks InjectorService thanked for this post
  7. #80
    Quote Originally Posted by JR IN JAX View Post
    Without mushrooming the threads? Got lucky!
  8. #81
    Feb 2014
    Missouri
    True metal urgy is definitely a thousand pages.
    Agreed with cutting
    theirs also also quite a few brass hubs which throw in another whole mess.
    As much trouble as hes having im tempted to think a flow torque shaft and standard hub or such got mixed or possibly A 15 or 19 spline. And it was jusst made to fit. Iirc one of the flow torque is longer one of them you can get a standard hub nearly all the way on. Or a short ft was on hit something and a standard was forced on over a twisted spline.
  9. Thanks Glastron1987 thanked for this post
  10. #82
    Agreed with cutting
    I think this is a great possibly.."Or a short ft was on hit something and a standard was forced on over a twisted spline". All kinds of crap could have happened.
  11. #83
    Had to be hitting something as look.
  12. #84
    Is it off yet? It's been a damn year already!
  13. Thanks Glastron1987 thanked for this post
    Likes Merc 2.5, Glastron1987 liked this post
  14. #85
    Plainville, CT
    Quote Originally Posted by Robby321 View Post
    I've been hitting it every way I can think of without damaging the unit.
  15. #86
    Nov 2019
    Canada
    Quote Originally Posted by Glastron1987 View Post
    Hit it with the dang grinder man! Haha!
    www.InjectorService.com
    Call/Text - 204-326-0390
  16. #87
    Plainville, CT
    After soaking in ATF-Acetone for many days, and then keeping maximum presure on the puller for several days there is some sign of movement as you may be able to tell from the photos. There is now a gap between the prop and the housing.
ID:	456127Click image for larger version.
    I took it one step futher by heating with my oxy-acetylene torch under pressure, and besides the flames, smoke, and making my basement smell, I did hear a few clunk noises like something may be freeing. For now I'll keep the pressure on it, maybe try to some more penetrating oil in spots I couldn't reach before, then heat it up again later.
  17. #88
    OK, thought looked weird.
  18. #89
    Hard to tell, but seems like prop moving but over the rubber and not the inner thats on the shaft? There is rubber between the two right? I run solid props over hub exhaust. Damn, seems hear of a lot of spun props and prop comes off easy. Ya got one stubborn SOB there!
  19. Thanks Glastron1987 thanked for this post
  20. #90
    Actually its one of those "free" items, and nothings free! No pun intended!
  21. Thanks Glastron1987 thanked for this post
  1. SS prop stuck on a V4 OMC gearcase
    By Sparkieboat in forum Props, Setup, and Rigging
    Last Post: 06-21-2015, 03:01 PM
  2. Removing prop stuck on shaft
    By twright55 in forum Props, Setup, and Rigging
    Last Post: 07-19-2010, 08:28 PM
  3. prop stuck on the shaft
    By rdkvector in forum Technical Discussion
    Last Post: 05-08-2010, 12:57 PM
  4. Removing stuck prop
    By riverrat321 in forum Technical Discussion
    Last Post: 06-27-2007, 06:06 PM
  5. What is the best way to get a stuck prop off?
    By PFord in forum Technical Discussion
    Last Post: 10-19-2004, 02:04 PM
