Results 46 to 60 of 77
Thread: 300R on a Checkmate?
10-01-2019, 09:17 PM #46
JUPITER PULSARE thanked for this post
JUPITER PULSARE liked this post
10-01-2019, 10:55 PM #47
allstock liked this post
10-02-2019, 06:43 AM #48
10-02-2019, 10:46 AM #49
why the lower and prop shaft upgrade? especially with tune alone? the SHO comes with a sort of sporty knock off and the life span of the lowers with the charger have been pretty impressive. you could do a 200SHO with the ecu reflash to 330 for significantly less than a 300r or even a 250r. you could definitely do a 200SHO with charger kit and be almost on par with new 300R cost and I trust Yamaha a lot more lol
10-03-2019, 12:58 PM #50
Looking forward to seeing your new boat and hearing about your setup and numbers. The Verados have built in setback (about 4-5") in the clamp desing, so adding a lot of setback on the Verado powered Pulsare 2400 would create porpoise. I run an Atlas 8" setback Jackplate on my 2400/300 Verado Pro. I have a friend who was running a 12" jackplate plus a 1" thick transom plate on his 400R powered BRX and he had a lot of handling issues until we reduced the setback to 6".
Paramount 21/Merc 225 EFI
Cobalt 263/VP 8.1L
Nova Spyder 230/454 Mag
Barracuda 188CCR/Suzuki 140
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT/Merc 175
Talon T-21/Mercury 245hp carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/454 Mag
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat
SeaRay 17' Seville
10-03-2019, 01:33 PM #51
5000 RPM
- Sep 2019
- Lake Keowee, SC
- 248
- 10
- 27
- 73
Yes you are correct, the AMS is standard on the Verado (old and new V8's) and has about 4.5" of set back. Checkmate sets those up with about 6" of set back (so a total of about 10" - 11") and I drove a factory set up 400R in Bucyrus with Dean. Came on the plane easy and no porpoising (at least at the speeds we ran it). The factory uses 10" set back with a conventional mid section like my 300R. In 2015 (I believe but should ask Dean again) they moved the windshield forward (on the 2400) to move the CG forward and make it less likely to porpoise. Dean told me the previous BRX left the factory about 2 months ago and he had it up to 5800 rpm with a 25P Trophy and it was running 70 mph with a 300 PRO XS V8. The owner did not want him to open it up, but Dean said he thought he could have easily hit 6000 - 6100 rpm.
10-03-2019, 01:36 PM #52
5000 RPM
- Sep 2019
- Lake Keowee, SC
- 248
- 10
- 27
- 73
Hi again. During conversations with Dean in the last few months, he mentioned that there is a Mercury engineer that owns a 2400 Pulsare (forgot if it is a BRX or long deck like mine). He removed the engine he had and installed one of the new 450R engines. Dean said that is all he knows, nobody mentioned anything about the performance, so apparently there is a 2400 with a 450R on it as well!!!
10-03-2019, 02:35 PM #53
10-03-2019, 02:36 PM #54
10-03-2019, 03:08 PM #55
10-03-2019, 04:57 PM #56
i got curious WavetoWave and had to ask Nizpro about the lowers, heres what they said:
The lower units are still proving to be very reliable, on customer boats that are fitted with superchargers that can weight up 29,000lbs in quad engine set ups down to high speed bass boats we have seen one failure. That was on a flat bottom 22 footer with a hydraulic jack plate using a offshore series engine, The customer simply ran the engine to high and cooked the lower unit until the prop shaft seal fell out draining the oil and the gearbox failed. I don’t believe blaming the supercharger for this failure is appropriate. Many of the other boats have now done 600 hours plus on standard lower units.
I would have thought more failures would of occurred by now but that's what they state.
Greg G liked this post
10-03-2019, 08:26 PM #57
10-03-2019, 08:30 PM #58
Supporting Member
- Jul 2004
- Connecticut
- 6,253
- 520
- 210
- 1078
- 1133
10-03-2019, 09:53 PM #59
On a quad engine setup with the gearcase submerged, not a big deal. Surfacing a single engine, running 95+, no way. Hydro-Tec has a fat shaft they offer, the SHO lower mod moves the water intake lower as well. Solid mounts, and the ECU flash make it a little bit involved. Surfacing the SHO, you will break that prop shaft. It's actually common to break or bend, that's why the fat shaft is so popular. The Yamaha only has 1.75 gears too, so the Merc has an advantage there with the new 1.60:1 Sport Master. Hydro Tec does make a 1.62 gear set for the fat shaft SHO as well.
HT fat shaft: https://www.hydrotecmarine.com/shop/...uty-propshaft/
Some guys used to convert to a sport master on the Yamaha, but that's a lot of work, and I don't think it worked well from what I understand.
I love the project though, not trying to be negative at all. I like those engines, really want to see it. It won't necessarily be cost effective though. A Yamaha with all the modifications adds about $4k in extras just to get it close to the Merc.
A certified pre owned 250 ProXS is $13k with warranty and will be very fast mid to high 80s?. A 250R is about $19k. 300R, about 25k?? maybe more.
I love a 21 Pulsare, I think you'll find that moving that needle past 97 is going to be tough, Wildman did it, with a perfectly setup rig. To get past that you'd need to make it lighter, blueprint the bottom, and add power. It's not super aerodynamic at those speeds. You definitely don't want to break a prop shaft at that speed in that boat.
4.2 SHO gearcase. It's not a sport master!
10-03-2019, 09:54 PM #60
300r could be up for sale
By schiadart in forum Outboard EnginesReplies: 14Last Post: 09-23-2019, 12:39 PM -
600 hp 400 r + 500 hp 300r
By Chaz in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 45Last Post: 07-18-2019, 07:14 AM -
1.60 Sporty now available for 300R
By mach351 in forum General Boating DiscussionReplies: 26Last Post: 04-16-2019, 10:56 AM -
300r
By Wild Bill in forum General Boating DiscussionReplies: 10Last Post: 03-29-2019, 10:38 AM
