Page 8 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 106 to 120 of 215
  1. #106
    I'm so glad to see that the stringer is foam core
  2. #107
    made the hole a little bigger to see the bottom of sponson
    lots o' water
  3. #108
    we got lots of foam for a small area
  4. #109
    Jun 2018
    Floating around
    Your rolling now Noli!
    Im surprised those foam holes were not sealed from the factory
  5. Likes noli, TwzteD liked this post
  6. #110
    Mar 2009
    Saint Lucie Florida
    Stupid on the builders part to not add a layer or two of glass over the holes.. That really Irks me, simple step could ruin a good boat. Most people don't want foam in their boat but if you seal it properly it should never get wet. Here is my boat, the holes you see are plugs cut from the floor for plugs to to mount seat and tank. what you see in the picture is the bottom layer of glass on the floor notice there is no hole. Its completely sealed and the plugs will get glassed in also. Unfortunately most builders cut corners and it sucks for the owner when the boat gets filled with water and gets heaver, makes a restoration inevitable.
  7. Likes noli liked this post
  8. #111
    Some builders leave the holes open on purpose. The foam produces gasses for some time and their production schedule is so fast it will be a problem to cover the holes and not let them vent. Not good, but it appears yours are dry.
  9. Likes noli liked this post
  10. #112
    Mar 2009
    Saint Lucie Florida
  11. Likes noli liked this post
  12. #113
    oh mine? mine was all wet. I tot I was going to be the one in a million of Vegas XT that would be dry since the boat was not in use, but it was left out in the open field uncovered
    but put it this way, if they built the boats right, we won't have our projects to do, doh...kidding
  13. Likes tnelsmn liked this post
  14. #114
    so again my goal is to remove the foam-core/stringers and replace with sth better
  15. Likes tnelsmn liked this post
  16. #115
    My bad, I didn't read or look close enough. One boat mfg I worked at we glassed over the pour holes the same day. The foam boxes would blow out the laminate somewhere. Ended up just gell coating over the foam to stop MOST of the water coming in.
  17. Likes noli liked this post
  18. #116
    after studying the angles involved from the exploratory hole I made, I was able to cut the stringer and the foam in special angles that lessened my scooping of wet foam
    see the angles of the cuts
    and the foam along with the glassed-stringer came out in chunks....not planned but good for me!
    I like 'em chunkehhhh
  19. Likes TwzteD liked this post
  20. #117
    Quote Originally Posted by TwzteD View Post
    ...Here is my boat, the holes you see are plugs cut from the floor for plugs to to mount seat and tank....
    that's a great idea!
  21. Thanks TwzteD thanked for this post
  22. #118
    Jun 2018
    Floating around
    Are those plugs coosa?
  23. Likes TwzteD liked this post
  24. #119
    Mar 2009
    Saint Lucie Florida
    Yes they are, glassed on the bottom with t nuts installed. Will be glassed over and completely sealed.
  25. Likes W2F a V-King, noli liked this post
  26. #120
    both strbd and port stringers removed
