Results 106 to 120 of 215
05-07-2019, 08:25 AM #106
05-07-2019, 08:27 AM #107
05-07-2019, 08:28 AM #108
05-07-2019, 08:31 AM #109
Your rolling now Noli!
Im surprised those foam holes were not sealed from the factoryHydrostream dreamin
05-08-2019, 06:11 AM #110
Stupid on the builders part to not add a layer or two of glass over the holes.. That really Irks me, simple step could ruin a good boat. Most people don't want foam in their boat but if you seal it properly it should never get wet. Here is my boat, the holes you see are plugs cut from the floor for plugs to to mount seat and tank. what you see in the picture is the bottom layer of glass on the floor notice there is no hole. Its completely sealed and the plugs will get glassed in also. Unfortunately most builders cut corners and it sucks for the owner when the boat gets filled with water and gets heaver, makes a restoration inevitable.
noli liked this post
05-08-2019, 06:48 AM #111
Screaming And Flying!
- 15,068
- 407
- 1453
- 6035
- 11679
Some builders leave the holes open on purpose. The foam produces gasses for some time and their production schedule is so fast it will be a problem to cover the holes and not let them vent. Not good, but it appears yours are dry.
05-08-2019, 07:31 AM #112
Well he did say it was wet. Not surprised with an open hole for it to flow right in at.
05-08-2019, 07:48 AM #113
oh mine? mine was all wet. I tot I was going to be the one in a million of Vegas XT that would be dry since the boat was not in use, but it was left out in the open field uncovered
but put it this way, if they built the boats right, we won't have our projects to do, doh...kidding
tnelsmn liked this post
05-08-2019, 07:53 AM #114
05-08-2019, 07:53 AM #115
- 15,068
- 407
- 1453
- 6035
- 11679
My bad, I didn't read or look close enough. One boat mfg I worked at we glassed over the pour holes the same day. The foam boxes would blow out the laminate somewhere. Ended up just gell coating over the foam to stop MOST of the water coming in.
05-08-2019, 07:54 AM #116
after studying the angles involved from the exploratory hole I made, I was able to cut the stringer and the foam in special angles that lessened my scooping of wet foam
see the angles of the cuts
and the foam along with the glassed-stringer came out in chunks....not planned but good for me!
I like 'em chunkehhhh
TwzteD liked this post
05-08-2019, 08:20 AM #117
05-08-2019, 12:19 PM #118
Are those plugs coosa?
05-08-2019, 01:01 PM #119
05-10-2019, 08:06 AM #120
