Results 76 to 90 of 145
Thread: CRT motor
03-01-2019, 03:20 PM #76
Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
I know my best 2.5 never made 450 even on methanol. Was actually quite a ways from it
Erik Kiser
Freddie Webb liked this post
03-02-2019, 01:45 AM #77
5000 RPM
- May 2002
- Ocean Springs, MS
- 116
- 41
- 32
- 11
- 266
Hey guys like all the good comments . Like peanut man said, been a long time coming and a ton of R&D to get the girls to were they are today . Jerry Bird from New Orleans Street Outlaws will be making an anoucement on a new venue with some 450 plus HP outlaw outboard drag boats . This will host and call out the fastest outboards from our country and a broad. CRT is excited and will suport his effort.
Think the rules are run what u brung 1200lbs nitrous and 100 Lbs off if u don't spray . Think i herd TV guys and 2 days of his formate , big bucks for the top 3 . 1/8 th mile i think ,but not 100% on his call . So all the fast guys out there that want to play , keep your ears on , he's about to call .
Capt.Insane-o, Michael Dixon, powerabout, DCSwetman, Hot Shot Merc, delawarerick, Kcraft, DockRocket004 liked this post
03-02-2019, 09:02 AM #78
5000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Real racing has turns. Both left's and right. Bring those things here into some real water "salt" and rip em rally style through the back country.
Seriously I had this idea the first time I saw that street outlaws. It might be watchable again if they did a boat version. Love to see that happen. Good luck.
03-02-2019, 12:31 PM #79
That's Special, I also heard they will be running in DSRA/ODBA this year?
03-02-2019, 12:38 PM #80
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
03-02-2019, 01:18 PM #81
03-02-2019, 01:39 PM #82
03-02-2019, 02:00 PM #83
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
03-03-2019, 01:18 AM #84
03-03-2019, 07:18 AM #85Rob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
Michael J Giesler liked this post
03-03-2019, 08:21 AM #86
No dog in this fight but if we`re talking about some sort of weight per cubic inch then it`s about time. I like that idea. No guessing just math.
03-03-2019, 08:56 AM #87
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 774
Weight per inch won’t work. It would heavily favor the 2.5. I’ll give an example, my boat raced pretty consistently at 915 lbs which gives you 6 lbs per cu inch. If you apply that to a V6 OMC at 218 cu in it would weigh 1308 lbs, a 265 cu in V8 would weigh 1590 lbs. The Mercury 2.5 would run away with it. The big inch engines would need to be under 5 lbs per inch
Erik Kiser
03-03-2019, 11:00 AM #88
Regarding weight , Someone explain to me why pro mod should be any different from the other spec classes ie lakeracer prostock 1400 mod etc? All these classes have a 2.5 weight penalty @ 5lbs per every cubic inch gained past standard bore.. 2.5 200 carries 100 more lbs than a 2.4 200 etc.. For example ,Ive added additional weight in LR for yrs just for using a .030 over bore so theres No reason a 2.6__ should run at the 2.5 weight. Most of these so called 2.6s are using Stroked cranks , 3.6 pistons
03-03-2019, 12:04 PM #89
5000 RPM
- Jul 2009
- Texarkana,AR
- 363
- 7
- 16
03-03-2019, 12:07 PM #90
Well, then you didn’t get the price for a powerhead. A shortblock is not the same thing as a powerhead.
A shortblock is a complete rotating assembly in a block, but without the cylinder heads.
If you add cylinder heads (which is a bigger deal on a 4-stroke than on a 2-stroke), you get a longblock.
If you add intake, fuel system, and ignition system, you get a powerhead.
If you add adapter plate, mid section, lower unit, cowlings, and a bunch of smaller stuff like exhaust pipe and linkages, you get a complete outboard engine.Markus' Performance Boating Links:
what is the fastest 2.0merc you have had, race motor or fishing motor v bottom please
By aaron78viper in forum General Boating DiscussionReplies: 29Last Post: 12-29-2016, 10:36 PM -
Those of you with decent setup: how much speed/rpm do you gain motor down vs motor up
By coreyc619 in forum Props, Setup, and RiggingReplies: 11Last Post: 08-05-2015, 06:45 PM -
Converting a 91 chevy truck to Hot Rod Motor carb motor need advise !
By Jay Smith in forum General Boating DiscussionReplies: 20Last Post: 11-29-2001, 10:45 PM
