Results 1 to 15 of 21
    Jan 2012
    Winnie, Texas
    1989 Bridgeport cylinder head options
    Hello everyone. I recently acquired a 1989 Bridgeport EFI with a bass boat attached to it. Long story short, it either went lean and ate a piston ring or had a locator pin issue. Cylinder #1 is toast as well as the head and cylinder, & #5 is down to 112psi. The rest of the motor is at 130-135#’s. I plan on steel sleeving the #1 and possibly #5 holes and replacing a piston and rings to get it back up to snuff but the port side head is chewed up pretty badly. Do the replacement cylinder heads have to be 2.4 Bridgeport EFI specific, or are there other options available for this motor that won’t break the bank? All help appreciated. This motor won’t live it’s life on the limiter, but I do want to have it’s potential still there just in case I need it lol. What would you guys do?
    1991 Charger Foxfire 195VF
    1989 Bridgeport EFI 240
    1980 Mako 17 Sportsman
    1986 Evinrude 120TL
    Dec 2001
    here is a 2.4 Xr4 block on E bay... NOS ya best bet for best build......
  3. Thanks BOWSER thanked for this post
    Likes BOWSER liked this post
    Jan 2012
    Winnie, Texas
    So you’re saying to get away from the BP altogether?
    1986 Evinrude 120TL
    Pekin, IL
    Bridgeports are good motors especially on light boats. Almost any head with correct bolt pattern will work. It's all about the cc. I would measure what ya got and proceed from there. The xr4 is also a good bet.
    Rock
    Team Junk
    Jan 2012
    Winnie, Texas
    Thank you. So are the 2.5 heads the same? Bolt pattern is very similar and that was my question, honestly. There’s an abundance of 2.5 heads where I’m at.
    1986 Evinrude 120TL
    Dec 2001
    2.5 heads....not PHs I posted a good deal....block... just add rings... steelbore... needs difrings...Hic
  8. Thanks BOWSER thanked for this post
    Pekin, IL
    The Bridgeport is a 2.4 motor. 2.5 heads will work but will likely need the side of the head shaved a bit as the 2.5 head is wider than the 2.4 head. And no they are not all the same. Different applications will have different cc needs. Bolt pattern is the same
    Rock
    Team Junk
  10. Likes BOWSER liked this post
    Jan 2012
    Winnie, Texas
    Here is the cylinder head in question. It’s not completely obliterated or anything, do you think it’ll be good to run if I dig out all the ring pieces embedded in the cast and smooth it out a bit? Also, the cylinder head is marked with .080. Surely it’s not a shaved head?
    1986 Evinrude 120TL
    Jan 2012
    Winnie, Texas
    The other side of the equation faired a little worse. To say the least lol
    1986 Evinrude 120TL
    Dec 2001
    looks like a mess....you need help...look at 2.4 block... cheeper....
  14. Likes BOWSER liked this post
    Pekin, IL
    Would not even consider running a cylinder head in that condition. Every spot currently occupied by debris once said debris is removed will create hot spots. Sharp edges heat up fast.
    Rock
    Team Junk
  16. Likes SS Minnow, BOWSER liked this post
    Jan 2015
    Quote Originally Posted by rock View Post
    Rock
    ^^^^^ What he said. I would not even consider running something like that. Paper weight.
  18. Likes BOWSER liked this post
  19. #13
    Jan 2012
    Winnie, Texas
    Alright, that’ll work for me. So find a 2.4l short block and some 20cc heads. Reassemble everything and back on the water. What am I losing in the process of doing this? HP? RPM? Is the fishing motor gonna hold up if I spin it hard every now and then?
  20. #14
    Dec 2001
    Fissn motor might have a better life.... the Bridge in BP causes probs....Yorin Texas..... find J smith......
  21. #15
    Shove some sleeves in it, some new top pinned pistons, have the head welded, injector service..run it.
  22. Likes BOWSER liked this post
  1. 1989 Mercury 2.4 Bridgeport blown up!! Options ?
    By joshyb in forum Technical Discussion
    Last Post: 02-22-2018, 07:16 AM
  2. Bridgeport nice cylinder head
    By Varmint in forum Misc. Parts and Accessories
    Last Post: 03-18-2015, 01:31 PM
  3. 1989 Venus power options
    By R.I.P. in forum Props, Setup, and Rigging
    Last Post: 12-25-2007, 06:20 PM
  4. Bridgeport ECU options
    By ProComp in forum Technical Discussion
    Last Post: 07-31-2007, 07:43 AM
  5. Rebuild options for Merc 200xl carb with bad cylinder
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 12-31-2005, 06:54 AM
