Results 1 to 7 of 7
    Aug 2009
    mpls,mn
    Merc v-6 2 piece adapter plate cooling set up
    Damned if I can find the old posts here? anyways 2.4 efi b/p with all steel sleeves on a stock 1988 200hp 2 piece plate Whats the best way to plumb it?
    Oct 2015
    Kentucky lake
    Need good temp gauge from head.
    Need good water pressure gauge from block.
    Rig it stock with popit valve and correct cover.
    Both Tstats in heads.
    3/8hose head to head then down port side head.
    Mercury used that design for a reason.
    I ran my BP 8000 rpm with crome and steel sleeves this way much safer than running it to cold. The two pieces gets rid of a lot of block water though the bottom of plate that you can't see..
    PM PYRO on here he ran that set up on his BP but think his was NiC.
    Aug 2009
    mpls,mn
    Thanks dave,I guess I need the info for both steel and nic motors as I just rebuilt two powerheads that are 2.4 200hp nic carb motors and both have one steel sleeve.
    Coated motors don't care where you run them at within reason, steel needs to be warm.
  6. Likes Dave Strong, nitro_rat liked this post
    Aug 2009
    mpls,mn
    So my nic motor has one steel sleeve I should run it warm?
    Quote Originally Posted by racervboat View Post
    Just make sure that cyl has enough piston to bore clearance, more important if you run forged pistons.
  9. Likes racervboat, nitro_rat liked this post
  1. Greg Moss' cooling mods / Drystacking the 2 piece plate
    By O/B Dude in forum Technical Discussion
    Last Post: 04-02-2024, 03:29 PM
  2. 260/280 1 piece adapter plate
    By tunnelmike in forum Parts Wanted
    Last Post: 03-31-2017, 02:09 PM
  3. Mercury Tech: 2.5 200 on 1 piece adapter: modify cooling?
    By bigboy in forum Technical Discussion
    Last Post: 03-25-2012, 07:03 PM
  4. Replies: 2
    Last Post: 07-05-2011, 12:47 PM
  5. 1 piece adapter cooling system
    By Ricky Bobby in forum Technical Discussion
    Last Post: 04-19-2011, 08:59 PM
