Page 6 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 76 to 90 of 181
  1. #76
    Read thru again don't know if I'm missing but..
    What kind of condition was the motor in..saw your keeping it! And nests
    It's got compression in all 4 holes, looks extremely clean (other than mouse nest) those old Johnrudes were tuff to wear out.
    So far I've been able to buy or make the parts I need.
  2. Thanks mrichartz thanked for this post
    Likes mrichartz liked this post
  3. #77
    Mar 2016
    cincinnati, ohio
    1 bys are there to hold the three transom pieces together, they will be removed later, right????
  4. #78
    Jul 2005
    AZ
    Quote Originally Posted by NICE PAIR View Post
    Any pics of the motor under the cowl etc?
  5. #79
    First post in the thread has a few motor pics.
  6. Thanks mrichartz thanked for this post
  7. #80
    Quote Originally Posted by 1954bmw View Post
    Correct, it's 3/4 plywood and it bent almost perfectly to maintain the curve or radius in the transom. I have screws pulling the foam/plywood back to the fiberglass
  8. #81
    Jul 2005
    AZ
    Thanks..I really need to look at it on my computer BEFORE I ask stupid questions can't see anything in my phone.
    I couldn't get it to enlarge and I thought it was a pile of rotten wood not motor with mouse nest
  9. Likes AZMIDLYF liked this post
  10. #82
    Things have been going so good I think I might be someone else.
    Got four layers in, gonna put the final 1700 bi-directional on tomorrow and start building my gunnel knee panels.
    Transom is getting stiffer than ..... well it's getting there.
ID:	423741 warm resin just works better. (it's even winter in CA)
ID:	423742 wet out 1700, clamp on layer 3.
ID:	423743 all layers are glassed 2" over and returned to hull.
ID:	423744 getting ready for number 3
ID:	423745 #3 went well set up by the time we got back from lunch. (I think I'll put on #4)
ID:	423746 screws seem to pull # 4 in adequately
ID:	423747 # 4
ID:	423748 Count em ... 4 layers, 4 layers glass, 5th layer 1700 bidirectional to finish tomorrow.
    I like the way everything went, don't know if I'd ever use wood in a boat again.
  11. Likes AZMIDLYF, tux974 liked this post
  12. #83
    FUJIMO
    The Historic Photo Master
    Join DateJan 2004LocationFloridaPosts14,217Thanks (Given)0Thanks (Received)454Likes (Given)0Likes (Received)4177Mentioned2 Post(s)Tagged0 Thread(s)
    Tell me more about the high density foam.
    brand ?
    can I layer it to get the curve my transom has ?
    specs on density/weight ?
    any problems with epoxy resin ?
    ...120 lb density is nice for transom foam. you pick the brand. the core is not where the strength is mostly, it comes from the laminate on both sides of any stringer, tranverse stringer, bulkhead, transom, etc. I've purchased hundreds of thousands of dollars worth of CoreCell. same with DivinyCell. so I recommend them, but any PVC foam will do that you can get. it all bends & can be vacuum bagged in place. before use, drill a lot of random 1/8" holes in the foam for air/bedding compound escape. Epoxy is fine but vinylester works well too.
    Thanks for your input, NP
    ...hope this helps...
    Yo Fugimo! Thank-you for steering me towards the foam for the transom, I'll probably never use wood again.
  13. #84
    Cleanup, add final 1700 & resin. Plugged holes in back with fiberglass rod.
ID:	423836 Click image for larger version.
ID:	423837 Click image for larger version.
ID:	423838 starting knees tomorrow.
  14. Likes tux974, AZMIDLYF liked this post
  15. #85
    Tomorrow is here!
ID:	423911 Click image for larger version.
ID:	423912 Click image for larger version.
    Please, no weak knee jokes, I'm gonna add several layers.
  16. #86
    You do nice work...........
  17. Thanks NICE PAIR thanked for this post
  18. #87
    Quote Originally Posted by tux974 View Post
    Be Careful ............................................... Don't eat too much.
  19. #88
    Short on time this A.M. got the knees glassed on outsides and did the inside with a strip of 1700 across the transom.
ID:	423962 Click image for larger version.
ID:	423963 Click image for larger version.
    Shorty say's "Get in the shower" we gotta be @ your sisters in blah, blah, blah
    Y'all have a good one.
  20. #89
    Dec 2001
    Not strong nuf for that V4 60 .... better go down to a 280 merc.....looking real good.
  21. Thanks NICE PAIR thanked for this post
  22. #90
    It's Saturday, so I goofed off a little. Got the knees close to finished, did some trial fitting on splash shield.
ID:	424059 Click image for larger version.
  1. The one that started it all-
    By JPEROG in forum Ebay Listings and Other Internet Listings
    Last Post: 06-10-2016, 05:30 AM
  2. Mercury Tech: Just getting started.
    By boatmann in forum Technical Discussion
    Last Post: 04-28-2010, 09:14 PM
  3. all new but never started
    By jersdeal in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 11-14-2009, 09:08 AM
  4. All done but getting started.
    By Damyankee in forum General Boating Discussion
    Last Post: 12-16-2008, 08:02 AM
  5. Please Help, cant get 2.4 XRi started...
    By JimG in forum Technical Discussion
    Last Post: 05-10-2002, 04:38 AM
