Results 106 to 120 of 140
Thread: Outboard Engine GEAR RATIOS!
11-21-2018, 10:51 AM #106
11-21-2018, 10:52 AM #107
NICE PAIR liked this post
11-21-2018, 10:54 AM #108
11-21-2018, 10:56 AM #109
6000 RPM
- Aug 2015
- Southeast
- 1,277
- 139
- 122
- 58
- 785
That's why I'm thinking a 28 may be more efficient than 30 or 32. But I'm sort of new to this stuff as you can deduce from my screen name. Seems like 34 or 35 is the max pitch prop I ever see, so thinking that's the top end of the range for being effective at pushing forward more than sideways. As stated, paddle wheel.
Anybody with direct experience care to chime in?
11-21-2018, 10:57 AM #110
As is mentioned in one post you can't increase pitch without limit, you get into bad prop walk at some point. I would not have wanted to run a 30 or 32 when I drove a Mod VP boat. 26-28 was enough. At some point the drag increases due to prop walk and there are problems with no advantage.
DangerNewb thanked for this post
11-21-2018, 11:24 AM #111
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
11-21-2018, 11:49 AM #112
Where are you coming from Joe, I'm NOT calling a greater reduction higher gear??
The problem I see is now we have 3 terms to define.
Ratio, Low and high gear and Greater reduction:
A 12:29 ratio is a Greater reduction than a 1:1. It's also a Higher gear Ratio!
In automobile's you Pull'er down to Low gear and shove'er up to High gear, but in actuality you were going from a High Ratio to a Lower Ratio.....SIMPLE!!!!WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
11-21-2018, 11:55 AM #113
WillySteve liked this post
11-21-2018, 11:58 AM #114
Book ms is ready. Hans took the math, converted it to CAD and printed out a 3D model of an SST45 cleaver. Plan is to cut one on a CNC machine once we're sure the bugs are out of his digitalization. I'll probably have to self-publish the book. Falls into a crack between physics and marine engineering that no published so far is interested in (won't be a money-maker).
11-21-2018, 12:57 PM #115
6000 RPM
- Aug 2015
- Southeast
- 1,277
- 139
- 122
- 58
- 785
Thanks you. Sorry to hijack the thread but it seems you guys have some knowledge and experience in this area. Guess what I'm asking is, if I'm more concerned with acceleration, is it more beneficial to get the the lower overall gearing (like 4th instead of 5th in car) I want more from the gear itself or from the prop? I'm thinking a prop is pretty inefficient compared to the gear itself, so a easier to turn lower pitch prop and harder to turn gear is better than a high pitch prop and easier gear. Assuming the prop range I'm talking about is 28 to 32.
Or is basically the same either way or so close to not matter? Not just hypothetical for me, I have a choice in assembling a lower and need to decide. Thanks for any input.
11-21-2018, 04:16 PM #116
- Dec 2001
- 9,501
- 271
- 191
- 1979
Tall pitch break prop.... Low pitch push boat forward......
11-21-2018, 04:20 PM #117
- Dec 2001
- 9,501
- 271
- 191
- 1979
Dave S. not spelling bee...... damm were is my Ring....Fell out of cracker Jack box......Yukon Jack...
11-21-2018, 04:45 PM #118
11-21-2018, 04:55 PM #119
SSt45
We've designed a cleaver for this SST45 rig (Hans driving) and have printed a 3D model. As it is the boat can run 2nd or 3rd nationally in either circuit, NGK or Powerboat Nationals. But we're stuck with 1:1 gearing.
11-21-2018, 10:40 PM #120
6000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Such a interesting read
btw torque converters have a ratio 2:1-3:1
to answer one question! Here it is torque x time = distance is the most basic way to express accelerating. The real formula is more complicated. The more torque can be applied over a given time the more acceleration occurs. Hp is a made up number to express torque and rpm
gear ratio never effects the engines power curve but it does change the rpm required to achieve a specific action. If prop theory holds archiving 25mph with 1:1 say at 2000rpm with the same prop it would take 4000rpm at 2:1. Mechanical advantage theory has you apply twice the torque and accelerate faster.
Of corse adding pitch slows rpm gain and reduces average applied torque. So you never really see that gain. Basically once you repitch to the operating range so your crank bearings last and you don’t bend a rod switching between 1.87 and 1.62 the gains will be negligible unless your in a drag race.
Because less pitch is easier to spool up (increase rpm) if you ran applied torque numbers with proper pitch you almost come out even and real world testing is needed.
And even vent most of that in not fully accurate due to all the real world variables and just general truths.
Forinstance the 3.0 merc have the low end strength of wet toilet paper throws most of that out the window.
B.A.T. Automotive engineering
Gear ratios
By Superdave in forum Technical DiscussionReplies: 0Last Post: 09-21-2014, 07:49 AM -
Omc v4 gear ratios??
By SSweet87 in forum Technical DiscussionReplies: 4Last Post: 08-04-2011, 07:33 PM -
OMC Tech: gear ratios?
By flabum1017 in forum Technical DiscussionReplies: 5Last Post: 02-17-2011, 02:53 AM -
gear ratios
By Deacon in forum Technical DiscussionReplies: 4Last Post: 07-21-2008, 06:32 PM -
Mercury Tech: different gear ratios
By JAFFA in forum Technical DiscussionReplies: 7Last Post: 07-14-2008, 07:06 AM
