Page 14 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 196 to 210 of 293
Thread: 2.5 ff rebuild
  1. #196
    Jul 2008
    Denton, Md.
    CONGRATULATIONS!!!! Quite the accomplishment!!! Makes me want to tackle one all that much more.
    We only go through this circus once...so enjoy the rides!!!
  2. Thanks Merc 2.5 thanked for this post
  3. #197
    Apr 2018
    Maine/Ma
    Congrats, well done.
    it's been enjoyable following along with your project, glad to see your hard work and effort has paid off.
  4. Thanks Merc 2.5 thanked for this post
    Likes Merc 2.5 liked this post
  5. #198
    Sep 2017
    Ashland city tn
    Little update here.
    Did compression test after bout 30 or so min idle time maybe little more over couple sessions of letting it cool down completely, I came up 138 -140lbs. I have a feeling its gonna come up some more?? Whatcha think. There is less than a hr of idle on hose
  6. #199
    Nov 2016
    Missouri
    Congrats Merc on your achievement..
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
  7. Thanks Merc 2.5 thanked for this post
  8. #200
    Sep 2017
    Ashland city tn
    Any comments bout compression? I'm gonna run another 30 min tomo b4 its maiden voyage and recheck it
  9. #201
    Sep 2017
    Ashland city tn
    Another quest guys. When u set your idle on the hose and your happy with it , what does it end up being? Avarage? Does it idle up atdc headed toward 0 or idle down? This may b a stupid question but... for some reason I think its off, it idles way to high closer I get to 0.
  10. #202
    800 on the hose is about 650 in the water because of the added back pressure. I think my 2.5 200 EFI engine is 4 deg btdc. Idles at 650. Set it in the water after it is warmed up is best way.
    Sep 2017
    Ashland city tn
    At 4 deg I'm double that?? Carbs shut
  12. #204
    Pekin, IL
    Good compression numbers. Heat cycles important. I have seen idle timinmg numbers all over the place. Like Vking said, set it in the water and go boating.
    Rock
    Team Junk
  13. Thanks Merc 2.5 thanked for this post
  14. #205
    Nov 2016
    Missouri
    My 200 xri idles around 1,000 on muffs and so does my 135 merc carbbed..about 650 - 700 in the water.
    1995 200 XRI
  15. #206
    May 2014
    Livingston, Louisiana
    I usually see a little increase in compression after completing break in, you should still be ok though. Like stated set idle timing on the water. Depending on carbs, idle timing varies due to different amount/size of holes in butterflies allowing different amounts of air with throttle plates closed. Set it to what makes your combo happy and enjoy it! Congrats on your build!
  16. #207
    Sep 2017
    Ashland city tn
    Gonna take it out when sun come out warms things up a bit. Should I keep my 28 chopper on it or use sumthin smaller?
  17. #208
    May 2014
    Main thing is you don’t wont it laboring, especially in the first few hours. You want to run it in the free and happy range and vary the rpm, may be easier to do with a smaller pitch. And let her warm up good before ya take off
  18. Likes rock liked this post
  19. #209
    Sep 2017
    Ashland city tn
    Motor is very very strong down low!! Whst plugs do I need to get for reading and runnin?
  20. #210
    May 2014
    NGK B9HS10 work well. Need to use them to make sure ya got enough fuel on the water. Really need to watch piston wash when fine tuning after break in. But good idea to watch plugs like a hawk during break in, it’s guick and easy to pull over and pull a plug and take a look. Good idea to start a little rich and work ya way down after break in complete.
  21. Likes bullet123 liked this post
  1. Rebuild!
    By Merc 2.5 in forum Technical Discussion
    Last Post: 08-12-2018, 04:49 PM
  2. best place for powerhead rebuild/lower rebuild on Long Island?
    By play2win in forum Technical Discussion
    Last Post: 08-08-2011, 01:49 PM
  3. Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
    By Liberator*21 in forum Technical Discussion
    Last Post: 10-06-2010, 06:39 AM
  4. Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
    By rickyo in forum Technical Discussion
    Last Post: 06-05-2010, 04:08 PM
  5. Need Rebuild on CLE
    By bigmotor in forum Technical Discussion
    Last Post: 07-14-2005, 10:06 PM
