Page 2 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 16 to 30 of 181
    Mar 2016
    cincinnati, ohio
    Have you decided what you are going to fill the void with????
  2. #17
    Quote Originally Posted by 1954bmw View Post
    void ??
  3. #18
    Day 3 ... took most of the day to finish grind and clean up.
    I put one layer of 1700 bi-directional with 635 thin epoxy ... just to put a little where Glasspar forgot to.
    Spent the rest of the day cleaning up the mess i made in the flurry.
    Who has an Idea what kind of pour foam I can use to fill the fiberglass stringers (floor support) with? looking for high strength not the kind that vaporizes with use.
  4. Likes tux974 liked this post
  5. #19
    Mar 2016
    cincinnati, ohio
    Yes sir, what are you going to use for the transom????
  6. #20
    I am planning on layering in 3/8 plywood as Glasspar did, the big difference is I will seal the wood and glass each layer in. I also plan on putting a plug of solid wood @ each of the holes so no end grain is exposed. I figure if theirs lasted 50 years, there is a chance I won't have to do this again. ;-)
  7. Likes AZMIDLYF, Will hedrick liked this post
  8. #21
    Marine ply, Baltic birch, mahogany ply?
  9. #22
    Probably marine ply, are there any non wood fillers that have the same strength as bent laminated plywood?
    Because of the splash well, you cannot run knees up very high. Glasspar just built up fiberglass 12" wide on the center of hull up the transom plus the side walls of the sump/center ribs were extra heavy.
  10. #23
    Had the same situation, splash well. Built it 1 3/4"marine + mahogany . Stringers went high and floor tied all together. Hundreds of hrs later, 8 season of fun in whitecaps 80% of the time, glad I went thick. Plus the glass layers to the corners and floor and stringers and bilge area. Tinted it white. Not a heavy motor at 260lbs , 140 Chrysler. Similar to the Johnson.
  11. Thanks NICE PAIR thanked for this post
  12. #24
    Here's some foam options for you....http://www.uscomposites.com/foam.html
  13. Thanks NICE PAIR thanked for this post
  14. #25
    4lbs...Yes, No?
  15. Thanks NICE PAIR thanked for this post
  16. #26
    4lbs...Yes, No?
    I'm having second thoughts on foam, if it bulges the bottom, I'm screwed, I'm contemplating pulling the rest of the floor and using the center floor supports to layup some knees against. If I reinforce the hull 12" wide with walls to form the sump and also use the walls as knees, I can kill 2 birds with less than 35 rocks. just thinkin out loud. ;-)
  17. Likes Will hedrick liked this post
  18. #27
    no need to place pieces of solid wood where the holes are, replacing the plywood. make a fullsize one piece transom template. transfer onto A-B exterior ply, of the total thickness of transom ply you need. assemble this total thickness on the floor, with waterproof glue or epoxy or matt & resin, screwing together with drywall screws, which you can remove later. drywall screws bite & draw the wood together the best & are inexpensive. with all this said, I wish more people would use high density foam when rehabbing transoms & stringers. its so freaking easy & a superior product.
  19. Thanks NICE PAIR thanked for this post
  20. #28
    The transom has a bow built in to it, I plan on laminating (for lack of a better word) it in 4 layers of 3/8.
    Does high density foam have the strength for a transom?
    This particular boat has no room for decent knees, and the splash well is not a structural part of the boat. Now that I said that, I'm putting in a new floor, I could glass in the well and use it for added strength.
  21. #29
    Day 4
    Well I couldn't do it, If I foamed under the floor and anything went wrong, I'd have an UN-repairable boat
    So here's the new deal.
ID:	421473Click image for larger version.
ID:	421474Click image for larger version.
ID:	421475Click image for larger version.
ID:	421476Click image for larger version.
  22. Likes tux974, TwzteD liked this post
  23. #30
    Quote Originally Posted by tux974 View Post
    Very nice!....
    I see you like playing with that nice Skil saw, plywood and fiberglass......
    I can't help myself Tony, I've got it out again.
  24. Likes tux974 liked this post
  1. The one that started it all-
    By JPEROG in forum Ebay Listings and Other Internet Listings
    Last Post: 06-10-2016, 05:30 AM
  2. Mercury Tech: Just getting started.
    By boatmann in forum Technical Discussion
    Last Post: 04-28-2010, 09:14 PM
  3. all new but never started
    By jersdeal in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 11-14-2009, 09:08 AM
  4. All done but getting started.
    By Damyankee in forum General Boating Discussion
    Last Post: 12-16-2008, 08:02 AM
  5. Please Help, cant get 2.4 XRi started...
    By JimG in forum Technical Discussion
    Last Post: 05-10-2002, 04:38 AM
