Results 226 to 240 of 496
Thread: 13' Bullet 130 Rebuild & Repower
10-11-2018, 12:48 PM #226
Looking great !
TwzteD liked this post
10-17-2018, 06:25 AM #227
Thanks! Started working on the bottom, slow process haven't had a lot of time to get much done but looks better already. Basically just sharpend up the back started leveling the pad and sharpening it. It's definitely a time consuming part, luckily the Adtec dries quick but lots of filling g sanding filling and sanding. But hopefully worth it in the end.
10-17-2018, 07:38 AM #228
Screaming And Flying!
- 15,036
- 403
- 1439
- 5970
- 11607
Looking "sharp"...Nice job, and it will be worth it..
10-23-2018, 05:58 AM #229
10-23-2018, 06:28 PM #230
Got a few mins today to spare so I repaired some of what appears to be trailer impact damage on the bottom. What's your opinions on sharpening up the keel a little bit where it starts to "Vee" up to the bow? Any reason to or not to? Aside from making it to Sharp and making it easy to chip off will it help cut through the waves better or is that sharp enough and not really matter.I mean I figured I'd ask since it's already flipped over and I'm working on it.
10-23-2018, 07:38 PM #231'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
10-23-2018, 09:34 PM #232
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,981
- 678
- 1076
- 1910
- 7922
- 4 Post(s)
You won't be running on the keel. Make sure the pad is true and the trailing edges are very sharp. A sharp keel also allows the bow to drop further and could provoke a worse case hook if were to drop off the pad at speed.
I have a guy that really wants one of formula motors that you have. If you have any interest in selling it to go bigger please let me know.
10-24-2018, 05:01 AM #233
NICE PAIR liked this post
10-26-2018, 04:56 AM #234
10-26-2018, 05:55 AM #235
5000 RPM
- Mar 2016
- cincinnati, ohio
- 694
- 150
- 35
- 287
- 205
Sweet
10-27-2018, 06:09 AM #236
10-28-2018, 11:54 AM #237
5000 RPM
- Mar 2016
- cincinnati, ohio
- 694
- 150
- 35
- 287
- 205
What kind of drain plug are you going to use to fill that huge hole in the back????
10-28-2018, 12:37 PM #238
I might look ok big but it's just a normal 1" plug..
11-16-2018, 08:12 AM #239
This thing is incredible, looks like it will be a blast when finished! You're doing great work. Good motivation for me and my Hydrostream project this winter. Thanks for taking the time to document all of it. Lots of good advice in this thread.
11-16-2018, 08:24 AM #240
Evinrude XP200 Rebuild or Repower
By Stoker88 in forum Props, Setup, and RiggingReplies: 6Last Post: 09-09-2020, 11:06 PM -
83 Bullet Rebuild Update
By One Oldman in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 06-02-2013, 10:10 PM -
30' velocity rebuild/repower/reeverything
By biohzrd in forum General Boating DiscussionReplies: 66Last Post: 08-03-2010, 10:39 AM -
Repower advice: OptiMax or rebuild 2.5EFI
By mercfan1 in forum General Boating DiscussionReplies: 8Last Post: 11-11-2008, 09:02 PM
