    Most people would be stunned to learn how much these prop balancing jigs cost and how fragile the wheels are. If you let the shaft bump a wheel while you are setting up, you likely make a dent in the wheel and the jig is out of commision until repaired. Been there, done that, got the tee shirt. At least the place I worked had their own in-house machine shop to do the repair same day without sending it out. We had a small enclosure so breezes and drafts would not try to turn the props while they were on the balancing jig, these things allow that much precision.
  2. Likes denny2 liked this post
  3. #10847
    Would it be simpler to use an electronic machine?
  4. #10848
    Fond du Lac WI
    I can remember seeing a bunch of castings and half machined castings in the scrap bin at Plant 4 many moons ago. Another Merc project that went nowhere, along with Blackhawk, Blacktrac, Autotrim, Hydrasteer, Culvert drive, hell I can't remember them all! JFL help me out here!
  5. Likes Mark75H liked this post
  6. #10849
    They cost even more and aren't simpler to use
  7. #10850
Page 724 of 1894 FirstFirst ... 224 624 674 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742 743 744 745 746 747 748 774 824 1224 1724 ... LastLast
