Page 15 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 211 to 225 of 241
  1. #211
    Aug 2015
    NE Tennessee
    How is that knock it warning system working out?
  2. #212
    Nov 2013
    Oak Hill Fl.
    3.0L WMH-47 carbs work killer on a 2.5L
    Attached Thumbnails Attached Thumbnails WHM47.jpg   3.0l WMH-47.jpg   37023965_1764416643645812_2433368301993197568_n.jpg
  3. #213
    Nov 2013
    Oak Hill Fl.
    Next!!!!!!!!!!!!!!!!!!!!
    Attached Thumbnails Attached Thumbnails 180907_080310_5 (1).jpeg   180907_080308_3.jpeg   180907_080310_4.jpeg   IMG_0935.jpg
  4. #214
    Nov 2013
    Oak Hill Fl.
    O and picked up this TURD for $1000 to run between blow ups................
    98 2.5 EFI off shore FF block. added a 260 39# regulator. throttle no progression linkage. Boysen power reeds and .050 of the heads. steel cage rod bearings and large SPS bolts.
    Suppose to be gods gift to the out board from what I am told. Same timing as a Pro Max 225 from the factory.
    Should turn a 30P at 7100 on the fuel dump rich limiter I am told.
    WILL SEE..................................
  5. #215
    No..the 225 PM has different things.
  6. Likes texasvector liked this post
  7. #216
    Dec 2001
    Nice Turd.....
  8. #217
    Nov 2013
    Oak Hill Fl.
    No thy are the same have the 225 print from LA sleeve and the 98 200 FF block measures the same as that print. Even asked my bud DEEZ NUTS and he said YUP!!!
    Also has the second cut in the ex port like the 225 promax and 240 sport jet. only difference in the block is it has the small opening out of the chest and no cut in the rod slot.
    Same timings in the sleeve.
  9. #218
    Shreveport, La.
    Your correct about all that but then there`s the big difference in the front half when compared to the 225pm. A while back we tested both motors as they came from Merc with both being on 21ft Bullet Bass boats. The 200 had just a small amount of hole shot over the 225pm but once both boats laid down the pm rolled right on by. We tried several props and the story never changed. The pm is simply a more powerful motor.
  10. Likes tlwjkw, Capt.Insane-o, W2F a V-King liked this post
  11. #219
    TX......somewhere?
    if no difference why would merc build two different block halves?.. maybe ta save paint?
  12. Likes NICE PAIR, texasvector, Capt.Insane-o liked this post
  13. #220
    Nov 2013
    Oak Hill Fl.
    Yes the front half are different 200 is 5 and 225 is 7 reed setups. The 96 and up 200 FF has the sport jet larg 4 petal rubberized reeds also.
    EFI box tuning is different also. I am using the stock 200 A8 box.
    Now go and find a virgin low hr 225 and see if it goes for $1000 complete. Sold the lower for $500 and the charging system for $150 and the coil pack for $100. So how much $$$ is in this eng?????????
    The 96 and up 200 EFI FF block engines are cheep and plentiful.
    I am very interested to see how it runs in this almost stock state.
    I have seen lots of reports on how this eng is the tits on a cow. Well I will see if it is all it is cracked up to be this week end.
    What ever it is it should live a long life on the back of the Vector as the go to eng.
    You know there are lots of thing I could have done to it. BUT I said NO lets just keep this one what it is I may be supersized.
    It is what it is and it will stay that way...........
  14. #221
    I am running a 98 200 FF motor. Nearly stock. It performs real good. I did go to an a-11 box (200 pro max) and found it will run thru the limiter to 7k at least. Only things I have done was c. carson reeds and cleaned up the heads. Timed at 25*. Super unleaded fuel, oil inj. and spark box deleted.. Fast as a promax 225? I dunno. Pretty darn close? yes.
    Nov 2013
    Oak Hill Fl.
    How much prop can you spin at 7K?
  16. #223
    Nov 2013
    Oak Hill Fl.
    It is funny you make a simple statement "it has the same port timing as a 225" and the DRAMA begins...............
  17. #224
    28p Lightning et (labbed) running about 6800. Shaft about even with the pad. I had always heard the porting is similar, but not the same motor as a promax. But like you said, a good runner for not many dollars.
  18. Likes dwilfong liked this post
  19. #225
    TX......somewhere?
    tha FF blocks that are tha "tits" run acu's or 4949's with 56 lbs turnin' what most call "tiny" prop excess of 9 grand.. but think you will be pleasantly surprised with it tha way it is...… it should come home in one piece!
  20. Likes dwilfong, nitro_rat liked this post
  1. 20' Action Marine restoration/resurrection.
    By Hot Shot Merc in forum General Boating Discussion
    Last Post: 08-12-2023, 02:11 PM
  2. Cosworth 275 Resurrection
    By promax150 in forum Technical Discussion
    Last Post: 07-16-2015, 08:33 AM
  3. Aquabuff-Rallysport Resurrection
    By Checkmate2.5 in forum Detailing and Care
    Last Post: 03-26-2008, 07:21 AM
  4. 2.4 Resurrection
    By Surface Scratcher in forum Technical Discussion
    Last Post: 02-25-2008, 07:49 PM
