Results 541 to 555 of 740
Thread: Looper exhaust porting
05-22-2018, 11:56 PM #541
05-24-2018, 10:51 AM #542
05-26-2018, 04:37 AM #543
aj06bolt12r liked this post
05-26-2018, 07:04 AM #544
Capt. Please give us the performance gains with the mods you did. I'm interested to see if the rpms go up with the same setup (prop) as before.
I have been watching your project from the begining and am always learning. Thanks for sharing!
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
Captain75 thanked for this post
Laseraddict liked this post
05-26-2018, 10:21 AM #545
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
With a looper you can do more power with same rev range and/or move the power peak up the rev range
06-03-2018, 02:53 PM #546
Finally I had the time to try the new looper in the water!
I was very careful not to mess the motor up, even so I had to feel the throttle response
and I can assure you, I was not disapointed! This is a totally different motor the the previous 2.7 Fingerport. I will get back when I have some more time on the water, but first I need to put on a bigger wheel and check the wot timing with these compression numbers.
06-05-2018, 03:26 AM #547
Tomorrow I will fine tune the ignition and the wot timing.
How much advance is recomended?
140psi, 91oct.
Won’t be running above 6600rpms.
06-05-2018, 05:50 AM #548
5000 RPM
- Sep 2009
- iowa
- 679
18 degrees max.
1975 Hydrostream Ventura II
1987 evinrude 200xp
06-05-2018, 06:06 AM #549
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
25:1 then 40:1 ?
06-05-2018, 07:48 AM #550
I would set that timing around 16. atleast until you get the jetting all figured out, if you end up a little lean +140 compression + heavy boat =bad day, better off safe. I left both of my mod 3l loopers at 16 and they made plenty of power.. Dave
06-05-2018, 09:14 AM #551
06-08-2018, 05:52 AM #552
A little update, but without any real numbers due to break-in process;
Today I tried a 22” Raker, a prop I’ve had serious bogging issues with when running the 2.7 f/p powerhead. With this ph it just explodes out of the hole, running 16deg timing advance.
Timing adjust using the Reeves method...
On the lake
NosBoss liked this post
06-09-2018, 09:22 AM #553
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,633
- 21
- 270
- 219
- 524
- 5 Post(s)
Timing needs to be set at 5k under load. They dont all change the same amount.
06-09-2018, 03:37 PM #554
Nice clean setup.
06-09-2018, 08:50 PM #555
Agree,I'm guessing that waters cooold..
