Page 67 of 72 FirstFirst ... 17 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 LastLast
Results 991 to 1,005 of 1076
  1. #991
    MIAMI FLORIDA
    I'm sure Gordons V8 can easily make way more hp than the record boat had... Dave
  2. #992
    Central Florida
    Quote Originally Posted by H2OPERF View Post
    True enough but that 4 point outrigger is going to need way, way, way more horsepower than the classic Karelsen.
  3. Likes Instigator, Mark75H liked this post
  4. #993
    MIAMI FLORIDA
    Yea totally agree.. I'm sure the goal was to kinda copy another type of boat that has some what safely proven to lay-down and stay on the surface at 250+ but when you have 8000hp+ and twin Cr props that push the hull out of the water for the first 1/3 of the lane and completely different weight distribution so not much to compare to.. Copying R/C stuff is like apples to oranges too, the power/wing size to weight is nothing similar.. Look at an r/c helicopter or airplane they fly straight up like a freakin rocket , most real helicopters are near full power at a hover ..
  5. Thanks Mark Poole ModVP thanked for this post
    Likes olboatman, Mark75H liked this post
  6. #994
    Good thing them Hai-waian's didnt read the internet ....
    or the ice racers …
  7. #995
    MIAMI FLORIDA
    Only time the rear sponsons touch the water on an top fuel is when the engines at idle and the fronts don't hit until the water might as well be frozen..
  8. #996
    Jul 2012
    Lufkin, Texas
    I haven’t really been following this thoroughly but are you comparing a non-planing displacement hull canoe with an outrigger to an outrigger hydroplane?
    Josh Peterson
  9. #997
    Notice when the Second Effort boat is at speed the front is planted and the entire after plane of the hull is carried by the prop. The cross section shape and 'taper' of the wing section is designed to minimize aero drag and turbulence. The Starflite boat that went 131 mph was probably one of the best examples of a minimum touch prop rider. To go that fast with 89 cu. in. and with the props they had back then was pretty amazing.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  10. Thanks Instigator thanked for this post
    Likes Instigator liked this post
  11. #998
    PARADISE /Naples
    Talked to Monty, said Rick wanted the boat in Monty's name so it is, stuff is for sale .
  12. #999
    Nope , I'm sayin none of em had a 1970
    135 Chrysler stacker for power
    CUDA
    ​Now there's an accurate statement if I ever seen one !
  13. Likes nitro_rat liked this post
  14. #1000
    Cute. Fact is I know a LOT about fluid dynamics, drag and how it applies to boats. Just so happens, I've been racing kayaks for the last 7 years so I know a lot about what makes them go fast too. By the way, outrigger canoes are not as fast as racing kayaks that don't have outriggers.
    Did you happen to notice that Ken Warby switched back to the needle nose design boat after testing an outrigger like boat for quite a while? If anyone knows how to go fast, he does.
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
  15. Likes Instigator, Mark75H liked this post
  16. #1001
    Well hopefully it was cute enough to talk you down off the ledge a bit .
    Have racing kayaks changed over the last 7 years ?
    Has your computer or cell phone changed ?
    Have outboard motors ..
    Then no doubt the thoughts and idea's what it would take to
    cracks the 200 mph barrier with an outboard
    will change just as quick.
    The easiest job I have found is to stand at the fence and squawk about how much you know on a subject that has never been tried before .
    As someone who has skint his knuckles on this boat I have earned the right to express my opinion to the powers that be . Sometimes right , sometimes wrong , like it or not , but in the end this is the boat that Rick George wanted to use to set the world record .
    Yes it's a T/Fuel boat , they leap out of the water . Then ride on the front sponsons and the prop . At rest , the motor is so far forward the sponsons carry the weight of the motor and driver .
    Main fuselage :
    Not enough lift for ya ?
    It's carbon -
    bond a pair of strips on the bottom to pack air .
    Front sponsons :
    Removable , make each one look like a Mack Truck or half of a Action Marine hull . The runner of an STV as big or as small as you want .
    Rear sponsons :
    Gotta hold the motor out of the water at rest . After that the running surface can be as aero or hydro as your pocket protector can produce .
    I never liked the fact that they are not inline with the front sponsons . But at aprox four feet long they formed a lifting tunnel at the rear of the boat .
    Outrigger :
    It won't … err … shouldn't blow over . Right now the poles have separate canard wings with short wickerbills . All providing downforce . Those were just to get it going safely . "The windshield wetter" set . That whole area from back tip of the sponson to the front pole can easily have "pants" put on it .
    I'd still like to see the front tips tied together with a canard wing and an on the fly adjustable trim flap …. but at this point , I'm just another rail bird sittin on the fence squakin …
  17. #1002
    MIAMI FLORIDA
    Were all just talkin banter as trump calls it..I don't know much about a TF boat other than they are impressive as hell... you wait around all day watchin boats that haul ass but are not super impressive and your girls going... is it over yet can we go home now....and then the big boys line up.... and then it gets earily-quiet and all of the sudden there's an explosion then a huge wall of water that doesnt't fall back to earth until after they have alaready gone thru the lights on the other end... at that point everyone guys and gals go WFT was that.. HOLY SHIZIT and everyone grinning from ear to ear.. The circus is not the greatest show on earth..Dave
  18. Likes whipper liked this post
  19. #1003
    Ohio
    Everyone can keyboard engineer this all they want. I know Rick, Dan Ellison, Chaz, Monty and bunch others put a lot of time into getting one to the water. That is more than 99.999% of others can say. So I congratulate them on that feat.
    We had a good reason for going with the outrigger ourselves, but also had a hydro sitting here to. I know how I would tackle it again if I ever decide to. I would have my money ahead of time and be calling Chaz and those guys up.
  20. #1004
    Jun 2002
    Winter Haven Fl.
    My opinion which means nothing, I liked the rigger setup as it would be easy to add lift as you needed it, on a hydro it seems like it would be harder to take lift out once the boat was built?
  21. #1005
    Guido went 164? with a F1 boat. Somebody with a shrunk down hydro and a pissed off 2.5 can break this record. The rest is politics. The motor Monty and Chaz put together is more than capable, the safety spine of the boat is there,and by far impressive but the rest ain't gonna do it. I don't mean to be a dick but the impression of the twisted hull was a slob by the vids posted. Dave Bush is/was/maybe more on the right track.
    ANYWAY I'm going to crawl in to my abspestoes suit and await the flames. And **** the UIM
  22. Likes tlwjkw, AZMIDLYF liked this post
