Results 1 to 11 of 11
    Feb 2018
    NJ
    1992 Fountain Sportfish C/C 31'
    $49,000
    "Sundance"
    LOA: 31'
    Beam: 8ft 4in
    Minimum Draft: 2ft 5in
    Dry Weight: 5200lbs
    Fuel Tanks: 1 Aluminum (207 Gallons)
    (2) 2005 Mercury Verado, 275HP each, 150 hours
    This Fountain has low hours, and was recently repowered with twin Mercury Verado 275's. She is a center console with a cutty cabin and head, and has been meticulously maintained and is ready to be on the water. The Fountain is a low center of gravity vessel and performs well fishing or racing to the next place you need to be.
    The Fountain has a hand laid composite hull and deck manufactured with multi-directional fiberglass, high density coring, and inter-plastic vinyl ester resin. The hull and deck are laminated, thru-bolted, screwed and sealed together with heavy duty marine sealant/adhesive.
    At the stern of "Sundance" is a bench seat that can lay flat for a larger stern area. Right on the transom is a fish hold with a cutting board. Moving forward are two more bench seats, one at the helm and one facing backwards, with a full awning overhead for both. On the port and starboard sides are fishing pole and deck brush holders, along with more pole holders overhead. At the helm, is an older chart plotter and VHF radio with a stereo. At the bow is a cutty cabin with a porta-head. Cushions run overhead as well as below to sleep two. Sundance is a comfortable, fast center console that will do what you need it to, in no time.
    Myco Trailer included.
    Sundance is currently located in Maine in inside storage but will be moved to Wallingford, CT early spring.
ID:	400419Click image for larger version.
ID:	400420Click image for larger version.
ID:	400422Click image for larger version.
ID:	400421Click image for larger version.
  2. Likes Frank Molé liked this post
    What does this boat run top end and does it cruse at around 4K?
    Feb 2018
    NJ
    Hi Joe,
    What exactly are you asking? If it is MPH, the boat will easily do 60mph.
  5. Likes Frank Molé liked this post
    So it will cruise at 45 mph without killing it. That is what I was wanting to know.
    Please send me some detailed pictures when you have a chance. [email protected] I have interest.
  7. Likes Frank Molé liked this post
    Feb 2018
    NJ
    Hi Joe,
    Sent pics.
    Got them, I will be in touch.
    Feb 2018
    NJ
    **REDUCED** 1992 Fountain Sportfish C/C 31'
    Price reduced to $44,000
    Essex Ct.
    Is your Fountain back in CT I'd like to check it out. I'm in Old Saybrook. LMK thanks
    Dec 2012
    Detroit
    Mod deleted
    Big and slow
    Feb 2018
    NJ
    New price!!!!
    $41,000
  14. #11
    Jul 2015
    northern lower michigan
    Quote Originally Posted by KakaroT View Post
    Friend of mine runs 68-69 with same set up, i just flashed his ecus now to 340 should be 72-74 so far he tried a pair of 24 bravo 1 and on the limiter gona try a pair of 26
    boat rides amazing eho ever buys this is getting a nice boat for that price
    Have your friend get ahold of Brett at BBlades and try his 4 Blade O/B prop it rocks on this boat as I have a 1999 with 250 efi's with them. I hit 68-69 with stock motors and 4000 rpm @45 mph.
  1. 42 foot Jersey Yacht Sportfish Quality?
    By transomstand in forum General Boating Discussion
    Last Post: 10-27-2013, 11:40 AM
  2. Donzi, Proline, Baja, Fountain all being moved to Fountain plant.
    By Mr. Demeanor in forum General Boating Discussion
    Last Post: 12-14-2010, 12:37 PM
  3. Opinions on Fountain 25 Sportfish
    By blkmtrfan in forum General Boating Discussion
    Last Post: 11-22-2008, 08:03 PM
  4. 29 Fountain CC w/225 EFI'S
    By jdmek620 in forum Props, Setup, and Rigging
    Last Post: 09-25-2007, 05:32 AM
