Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by wellcraft17 View Post
    Place the bottom of the jack on the prop shaft and the wood in between the ram and bottom of the planing plate and pump the jack up a little a then check the shaft. Keep repeating this until you straighten the shaft.
    Is this an accepted way of straightening a prop shaft? Seems like the shaft should be removed to avoid damaging (brinelling) the bearings...
    Either way, I think I’ll pass!
    To straighten a shaft that has been removed is it done cold (with a press) or with heat?
    Josh Peterson
  2. #17
    Aug 2009
    mpls,mn
    Remove it press no heat,of the couple hundred I have had done don't know of one that has failed.Fishing and rec motors.
  3. Thanks nitro_rat thanked for this post
  4. #18
    Jun 2008
    Sardis Lake Oklahoma
    Speaking of shafts, it's amazing just how malleable the Merc 1" shaft is.
    Back in my Nitrous days I twisted splines on several shafts and never broke one. I did break a couple'a DS's at the top spline though. I've had a Fatshaft for 2 years and already lost a hub and prop due to the threaded nipple breaking off.....and NO Nitrous, just regular running!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
  5. #19
    Aug 2009
    mpls,mn
    Yeah willy,a Volvo penta sx stearn drive propshaft is a hefty shaft but they bend like butter and have had many straightened you get a file even close to one and metal is coming off haha
  6. Likes WillySteve liked this post
  1. Will a small shaft Mercury hub prop fit a 2015 150 HP 4 stroke shaft
    By 4Speed in forum Props, Setup, and Rigging
    Last Post: 05-16-2015, 03:15 PM
  2. Mercury 225 Prop shaft
    By GTRMick in forum Props, Setup, and Rigging
    Last Post: 05-20-2008, 03:44 AM
  3. 96 225 EfI Prop shaft removal
    By CNT in forum Technical Discussion
    Last Post: 05-04-2008, 11:02 AM
  4. Help prop shaft removal
    By johnny24 in forum Technical Discussion
    Last Post: 05-07-2005, 08:40 PM
