Results 1 to 15 of 25
Thread: Rod cap alignment tool
04-12-2018, 09:32 AM #1
Hello!
I just got an OMC Rod cap alignment tool by mail. The tool is brand new, but it didn’t come with any user instructions. The manufacturer refers to a OMC shop manual. The manual I’ve got doesn’t include any such instructions.
Anyone who are in possession of these instructions? If so, could you take pictures of
these pages and post them on this board?
Forkin' Crazy liked this post
04-12-2018, 12:44 PM #2
Member
- Jul 2007
- Bay City, Texas
- 95
- 10
- 11
instructions
Install Rod Cap Alignment Fixture, P/N 396749, before tightening rod cap screws. Align the flat marked “SET” on the rod engagement stop with the arrow on the frame. Position stop at the center setting (one line showing). Rotate adjustment knob 180° to lock in position.
Secure restraining jaw “C” and forcing jaw “D” to frame.1. Center position, one line showing 002484
IMPORTANT: Torquing the screws without Alignment Fixture, P/N 396749, or using an incorrect procedure could cause permanent damage to the connecting rod and crankshaft. To maintain accurate torque values, keep torque wrench extension length to a minimum.1. Forcing Jaw “C”
2. Forcing Jaw “D”21591/21594
Apply a light coat of outboard lubricant to the corners of the connecting rod and rod cap. Place frame on connecting rod using the following procedure:
• Position frame onto the connecting rod so the contact area of the jaw is centered on the side of the rod.
• Tighten forcing screw until jaws contact connecting rod.
• Slide frame down until adjustment stop contacts the rod cap. The groove lines on the jaws must be centered on the rod/crankpin diameter.
IMPORTANT: Make sure that frame is squarely in position and that rod and cap are aligned.1. Adjustment stop
2. Groove line34460
Tighten the forcing screw to a torque of 14 to 16 in lbs. (1.6 to 1.8 N·m). Do not overtighten.
Loosen both rod cap screws one-quarter turn.34461
Use Torquing Socket, P/N 331638, to tighten rod cap screws in three stages:
• Apply an initial torque of 40 to 60 in. lbs. (5 to 7 N·m) to both rod cap screws.
• Torque screws to 14 to 16 ft. lbs. (19 to 21.7 N·m).
• Apply a final torque of 30 to 32 ft. lbs. (41 to 43 N·m).
Loosen forcing screw and remove the frame.34463
IMPORTANT: Test at least three corners of the rod and cap joint with a pick. Joint must be smooth with no step.
You reap what you sow, corny but true.
04-13-2018, 01:10 AM #3
Ssv170!! Great, many thanks!
//Anders
04-15-2018, 11:28 AM #4
Ssv170...
Do you by any chance have the pics too?
This part is a bit hard I think:
”Tighten the forcing screw to a torque of 14 to 16 in lbs. (1.6 to 1.8 N·m). Do not overtighten”
I can’t even find a torque tool that covers as low values as 1nm...
Someone have a trick up their sleve? Just snug the forcing screw?Last edited by Captain75; 04-15-2018 at 11:45 AM.
04-16-2018, 12:50 PM #5
Member
- Jul 2007
- Bay City, Texas
- 95
- 10
- 11
inch pound torque wrench
04-16-2018, 12:52 PM #6
Member
- Jul 2007
- Bay City, Texas
- 95
- 10
- 11
04-16-2018, 06:23 PM #7
Being a po Floda boy, I've never used this tool. Does this mean my chit's gonna blow up?
baja200merk thanked for this post
04-17-2018, 03:10 PM #8
The more I think about this, the more strange it appears...
1.6-1.8; thats almost nothing!? You can almost accomplish that with your fingers!?
Can this really be right?
04-17-2018, 04:08 PM #9
04-17-2018, 07:05 PM #10
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
hasnt the tool got a clutch on the knob?
04-17-2018, 09:13 PM #11
5000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 14
- 68
- 34
Mine does , have a clutch in the knob .....
04-17-2018, 11:28 PM #12
04-18-2018, 07:06 AM #13
04-18-2018, 07:54 PM #14
6000 RPM
- Calgary, Alberta
- 1,142
- 22
- 63
- 359
- 182
There are 2 versions of the tool - early one had a built in clutch, later one just a 1/4” socket hole for small torque wrench as mentioned. As far as the torque value, I was taught by OMC Master Techs to just use gentle pressure with small 1/4” ratchet, been working perfect
Matt
Captain75 thanked for this post
frank jackson liked this post
04-18-2018, 10:09 PM #15
OMC Rod alignment tool
By flabum1017 in forum Misc. Parts and AccessoriesReplies: 0Last Post: 03-31-2018, 04:35 PM -
OMC rod cap alignment tool
By flabum1017 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 07-23-2017, 01:53 PM -
omc rod cap alignment tool-looper
By tony genovese in forum Technical DiscussionReplies: 18Last Post: 10-22-2005, 07:46 PM -
Omc Rod Alignment Tool
By DIAMOND in forum Technical DiscussionReplies: 10Last Post: 12-21-2003, 05:46 PM -
omc rod alignment tool
By charger19 in forum Technical DiscussionReplies: 10Last Post: 12-11-2001, 10:17 PM
