Results 61 to 75 of 275
Thread: Mercury 1994 2.0L 150
03-31-2018, 03:31 PM #61
part no.
91-77109A 3
ya, more than likely, gonna need it again...................
Glastron1987 thanked for this post
Glastron1987 liked this post
03-31-2018, 04:48 PM #62
Looks like a good luck marine piston.
nitro_rat liked this post
03-31-2018, 08:29 PM #63
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
Great to get the tool number if I do end up doing more than this one piston. I did end up finding a youtube video that showed a technique that was easy enough for me to follow. You put one end a ways past the notch, so that the other end just passes the notch. Hold the whole thing down while placing a small screwdriver in the notch and pry it towards the center from the top. That was a lot easier than the two other techniques I saw people use.
As for the piston, I have confidence it will work for me, but I would expect a dealer would have used a full replacement part.
04-07-2018, 01:45 PM #64
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
Got #3 piston back in with new rings. I did reuse the cap bolts with a drop of red #271 loctite. If not for the extra shipping cost on two bolts I (ideally) would have used new ones but since others have had good luck reusing them I have high confidence it will hold together. They torqued nicely, incrementally, to 30 ft/lbs. I was surprised how well it all went back together, and a long pair of needle-nose pliers helped a lot getting the lower rod bearings in place. One thing I did not like is that with the intake still on, I could pencil check the cap mating pretty well on one side, but not on the other. I’ll double check that later when I pull more apart for de-rusting. It does seem to spin well though. Next step will be to put the head back on. Can’t wait to try that compression test again.
04-08-2018, 02:55 PM #65
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
04-09-2018, 06:40 PM #66
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
So now I've got the 10 powerhead nuts and bolts off. If I just lift with a hoist should the engine along with the exhaust plate easily come off or should I expect to have to rap it and heat it up? Any tricks that will help?
04-10-2018, 07:00 AM #67
Should be 10 nuts, no bolts. Powerhead will lift off but you will need to remove 5 bolts and motor mounts( 2 more nuts and bolts ) to remove adapter unless you are on a 1 pc plate. If motor has been in salt you may need explosives. When I get one that wants to stick I pry on one of the two front studs and/or rear 4 studs being very careful not to damage threads. Put a little load on lift ring while prying.
RockTeam Junk
04-10-2018, 07:16 AM #68
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
Oh yes, I rechecked, it was 10 nuts. So would plate come off after motor is lifted off or before? I'm thinking lifting off motor first then worry about the plate.
04-10-2018, 07:19 AM #69
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,630
- 301
- 279
- 1791
- 1275
Plate comes off after powerhead
Josh Peterson
04-10-2018, 07:23 AM #70
be sure to take tha shift shaft loose at tha anchor bracket.. my achilles heel!
04-10-2018, 07:48 AM #71
04-11-2018, 07:42 PM #72
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
It looks like there is a pin that needs to be driven out through the shift arm that is very difficult to get at. Does that sound right?
04-11-2018, 09:25 PM #73
no...
7/16's nut/glide block on anchor bracket......
04-13-2018, 04:21 AM #74James H. W2F a V-King... Want 2 Fly a V-King
04-13-2018, 06:40 AM #75
5000 RPM
- Oct 2008
- Plainville, CT
- 873
- 478
- 30
- 449
- 78
When stripping the motor down I think I did remove that, but will double check.
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
