Results 1 to 12 of 12
Thread: EGT probes and wire
04-03-2018, 06:23 PM #1
Member
- Sep 2014
- Orange, TX
- 64
EGT probes and wire
Where is the best place to get new EGT probes and wire for 2.5 mercury for the bottom of divider pate? Brucato used to sell them but they don't anymore.
1986 STV Pro Comp/Sprint
04-03-2018, 06:54 PM #2
I buy these from Omega: 1/8" for use in the rifle drilled bolts. Fast, but don't live super long. Good thing they are relatively cheap.
https://www.omega.com/pptst/KMTXL_NMTXL.htmlKeith-
90 5.0 liked this post
04-03-2018, 06:56 PM #3
Member
- Sep 2014
- Orange, TX
- 64
Thanks! Do they carry wire too?
04-04-2018, 04:24 PM #4
Yes. Check this page for what you need:
https://www.omega.com/pptst/EXGG_KX_WIRE.htmlKeith-
04-05-2018, 08:13 AM #5
Supporting Member
- Jul 2013
- California
- 1,731
- 29
- 85
- 123
- 396
Hewitt Industries in Southern California. Manufacturer who makes them for most all of the gauge manufacturers.
04-05-2018, 09:09 AM #6
04-05-2018, 09:57 AM #7
5000 RPM
- Mar 2016
- cincinnati, ohio
- 696
- 151
- 36
- 287
- 205
Look and see if Omega offers the thermocouples in inconel sheath, should last longer then stainless steel sheath. GE had some with a platinum sheath, but those are ungodly expensive.
04-05-2018, 11:24 AM #8
Member
- Sep 2014
- Orange, TX
- 64
I ended up buying the probes from cpperformance for $32 each with the fittings,and 50’ of wire from omega for $50. We’ll see what happens
04-07-2018, 05:18 AM #9
Contact Exhaust Gas technologies. they have anything and Everything you need. http://www.exhaustgas.com/ProductDet...D=71&BasketID=
10-23-2018, 11:01 PM #10
10-24-2018, 10:37 AM #11
5000 RPM
- Dec 2002
- Paulina, LA
- 821
I have these from Omega, KMQXL-125U-6. Installed them 8yrs ago and still going with no issues.
10-24-2018, 10:53 AM #12
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
3 wire trim motor, can it be hocked to 2 wire electrics???????
By Bensy in forum Technical DiscussionReplies: 4Last Post: 04-30-2016, 07:31 PM -
Mercury Tech: *HELP* trim pump replacement/upgrade... 3 wire to 2 wire relay
By hst714 in forum Technical DiscussionReplies: 8Last Post: 08-15-2010, 03:00 PM -
Mercury Tech: Mercury 40 AMP 4 yellow wire or 2 wire question??
By skeeterboy in forum Technical DiscussionReplies: 9Last Post: 06-13-2009, 10:00 PM -
Power trim motor! 2 wire conversion for 3 wire system
By The Big Al in forum Technical DiscussionReplies: 1Last Post: 10-19-2005, 12:59 PM -
EGT probes on 3.0 225 Optimax... where do you install the probes?
By RUNWME in forum Technical DiscussionReplies: 5Last Post: 08-03-2004, 09:45 AM
