Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Mar 2005
    Frankford, Ontario, Canada
    Ceramic coating exhaust tuner?
    I am going to do the rings on my 280 soon.
    My guy and I are thinking of cleaning up the exhaust cavity on the block and ceramic coating the tuner. That is all I want to do to it, I think.
    Has anyone Ceramic coated the tuner and had any positive results?
    Or is it just not worth the effort?
    Thanks
    1983 HydroStream Vegas Stringer
    280 ROS
    Check out the Chrysler racing thread. The four carb stacker has had ceramic coatings applied to the pistons, chambers, and ex area leading to the stacks. He's happy with it and applied it himself.
    Swaintech coatings in NY has lots of info on the website.
    Florida Keys
    Our ODBA engine builder almost always ceramic coats the tuner plate. As for grinding on the 280’s chest.....I’d reconsider. Mercury did a pretty good job on that one, and except for some extreme high rpm racing applications I think you’ll find that you won’t gain much....maybe even lose some. Just my opinion.
    '95 STV "The Blue Goose"
  4. Likes baja200merk liked this post
    Ceramic coat the whole inside port to tuner end. Push the heat out the exhaust not heat soak it into the motor?
  6. Likes olboatman liked this post
    Mar 2005
    Thanks FMP will do.
    280 ROS
    I'm sure someone has done it completely, but I don't know where you'd find the info.
    Mar 2005
    Quote Originally Posted by mach351 View Post
    Thanks Mach351. I won't touch the exhaust chest then. Was hesitant from the beginning. Ceramic coating will get done.
    280 ROS
    shreveport,la
    Randy gave you good advice. The 280 chest is really good from Mercury. I vote yes on the ceramic coating
    Erik Kiser
  11. Likes Noah Burns liked this post
    Give Bud a call at East Coast Powder Coating as he knows and applies ceramic coatings. He is a member of S&F. 757-544-1787
    Gary
  13. Likes Slimm liked this post
    Gary
    You could coat your plow blade? Lol
    Early April looking cold
  15. Likes WillySteve liked this post
  16. #11
    Gary
    Frank I spray it with cookin oil....works ssssslick! Teflon would be the trick!!!! lol
    Gary
  17. Likes WillySteve liked this post
  18. #12
    Btw no mo sno!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  19. #13
    Crisco!
  20. #14
    NOPE......Pam!
  21. #15
    Blahaha, just got a silly visual of a guy wiping out a whole aisle in the grocery store, every time I hear Pam I remember seeing that happen, never mind.
  1. Faded Yellow Donzi, color correction and ceramic coating
    By WavetoWave in forum General Boating Discussion
    Last Post: 01-17-2018, 12:56 PM
  2. Ceramic Coating
    By frankydee in forum Technical Discussion
    Last Post: 11-01-2010, 07:29 PM
  3. Ceramic coating
    By Jeff "Yammer" in forum Technical Discussion
    Last Post: 09-18-2005, 08:30 PM
  4. Ceramic coating pistons
    By rottenbrock in forum Technical Discussion
    Last Post: 12-20-2004, 10:53 AM
