Results 1 to 14 of 14
    Aug 2004
    Venice, Florida
    3/8" compression 90 degree elbow for hyd steering
    I need to turn 90 degrees off this bulkhead fitting and connect to my steering hoses. 3/8 compression. I cannot find a 90 degree compression to compression elbow.
    Any help?
    21' Paramount
    Mercury 300 Promax
    Aug 2004
    Venice, Florida
    21' Paramount
    Mercury 300 Promax
    Aug 2004
    Venice, Florida
    And yes, Ill be taking care of the screws. Just mounted the fitting tonight.
    21' Paramount
    Mercury 300 Promax
    Aug 2004
    Venice, Florida
    21' Paramount
    Mercury 300 Promax
    Ft. Lauderdale, Fl
    Personally, I have never seen what you are looking for. You can get a 90 degree tube to tube double male and use a short piece of 3/8" copper tube (or stainless tube if you can find some) between the bulkhead fitting and elbow.
    Gothenburg, Sweden
    If it exists, Hoser would know...
    Ft. Lauderdale, Fl
    Best bet would be to have a hydraulic hose guy put elbow fittings on the hoses.
    Aug 2004
    Venice, Florida
    Quote Originally Posted by flabum1017 View Post
    I know but I already ran the damn hoses and really dont want to pull them back out. Maybe I could take the whole boat over to a hose shop if they can do it that way.
    21' Paramount
    Mercury 300 Promax
    Ft. Lauderdale, Fl
    Quote Originally Posted by Mr. Demeanor View Post
    They may have reusable fittings that will just screw on.............
    Parker makes a screw in comp fitting in 90 I believe. Gotta go to a parker store though. May even make a swivel pc.
  11. Likes One Oldman liked this post
  12. #11
    That’s a SeaStar plastic/Kevlar hose with machine installed O ring end.
    You need a reducing coupling 3/8 to 1/4 and use the SeaStar 90* with 1/4 pipe thread on one end or the HF 6400 ORB fitting.
  13. #12
    Ft. Lauderdale, Fl
    Quote Originally Posted by tux974 View Post
    The bulkhead fitting is a 3/8" tube; same as the 3/8" tubing fitting that uses a ferrule. SeaStar uses the o-ring fitting for the hose. He simply needs a 90 degree fitting to replace what's on the hose or go with the way I described in post #5. Better to go with new fittings on the hoses than to add multiple fittings and have more chance of a leak.
  14. #13
    I see it! Seastar fittings are all O ring. Sure less is better but I believe Seastar does not have a 90* for the hose end and since is their fittings probably the only one that would be able to install for security/safety reasons if they did.
    The other option is use a Seastar bulk head setup with 90* ends.
  15. #14
    Aug 2004
    Venice, Florida
    I rerouted the hoses. All done.
    Thanks
    21' Paramount
    Mercury 300 Promax
  1. Hydraulic steering 90 degree fitting question
    By mjw930 in forum General Boating Discussion
    Last Post: 03-21-2018, 01:03 AM
  2. My take "lib Arts" or a "Masters" degree..
    By Robby321 in forum The Scream And Fly Lounge
    Last Post: 01-08-2017, 11:46 AM
  3. Omc blocks and cranks 60 degree and 90 degree block made in england
    By goodride in forum Misc. Parts and Accessories
    Last Post: 12-23-2014, 01:21 PM
  4. Finally figured out how to do a "Degree", symbol, keyboard!
    Last Post: 11-30-2010, 07:02 PM
  5. I need a 6" 90 degree aluminum condiut elbow ( sweep )
    By Jay Smith in forum The Scream And Fly Lounge
    Last Post: 06-27-2006, 01:43 PM
