				Results 1 to 14 of 14
	03-03-2018, 11:12 PM #13/8" compression 90 degree elbow for hyd steering13' Biel tunnel AKA "Flight Risk"
 21' Paramount
 Mercury 300 Promax
	03-03-2018, 11:15 PM #2Last edited by Mr. Demeanor; 03-03-2018 at 11:21 PM. 13' Biel tunnel AKA "Flight Risk"
 21' Paramount
 Mercury 300 Promax
	03-03-2018, 11:21 PM #3And yes, Ill be taking care of the screws. Just mounted the fitting tonight. 13' Biel tunnel AKA "Flight Risk"
 21' Paramount
 Mercury 300 Promax
	03-03-2018, 11:43 PM #413' Biel tunnel AKA "Flight Risk"
 21' Paramount
 Mercury 300 Promax
	03-04-2018, 09:58 AM #5Personally, I have never seen what you are looking for. You can get a 90 degree tube to tube double male and use a short piece of 3/8" copper tube (or stainless tube if you can find some) between the bulkhead fitting and elbow. "One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
	03-04-2018, 09:59 AM #6If it exists, Hoser would know... Markus' Performance Boating Links:
	03-04-2018, 10:28 AM #7Best bet would be to have a hydraulic hose guy put elbow fittings on the hoses. "One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
	03-04-2018, 11:05 AM #8
	03-04-2018, 11:16 AM #9
	03-04-2018, 11:26 AM #10 Screaming And Flying! Screaming And Flying!- Join Date
- 15,055
- 406
- 1448
- 6000
- 11656
 Parker makes a screw in comp fitting in 90 I believe. Gotta go to a parker store though. May even make a swivel pc.
	 One Oldman liked this post One Oldman liked this post
	03-04-2018, 02:28 PM #11That’s a SeaStar plastic/Kevlar hose with machine installed O ring end.
 You need a reducing coupling 3/8 to 1/4 and use the SeaStar 90* with 1/4 pipe thread on one end or the HF 6400 ORB fitting.
	03-04-2018, 03:14 PM #12The bulkhead fitting is a 3/8" tube; same as the 3/8" tubing fitting that uses a ferrule. SeaStar uses the o-ring fitting for the hose. He simply needs a 90 degree fitting to replace what's on the hose or go with the way I described in post #5. Better to go with new fittings on the hoses than to add multiple fittings and have more chance of a leak. "One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
	03-05-2018, 06:15 AM #13I see it! Seastar fittings are all O ring. Sure less is better but I believe Seastar does not have a 90* for the hose end and since is their fittings probably the only one that would be able to install for security/safety reasons if they did.
 The other option is use a Seastar bulk head setup with 90* ends.
	03-05-2018, 09:03 AM #14I rerouted the hoses. All done.
 Thanks13' Biel tunnel AKA "Flight Risk"
 21' Paramount
 Mercury 300 Promax
  Hydraulic steering 90 degree fitting questionBy mjw930 in forum General Boating DiscussionReplies: 18Last Post: 03-21-2018, 01:03 AM
  My take "lib Arts" or a "Masters" degree..By Robby321 in forum The Scream And Fly LoungeReplies: 1Last Post: 01-08-2017, 11:46 AM
  Omc blocks and cranks 60 degree and 90 degree block made in englandBy goodride in forum Misc. Parts and AccessoriesReplies: 0Last Post: 12-23-2014, 01:21 PM
  Finally figured out how to do a "Degree", symbol, keyboard!By Robby321 in forum The Scream And Fly LoungeReplies: 41Last Post: 11-30-2010, 07:02 PM
  I need a 6" 90 degree aluminum condiut elbow ( sweep )By Jay Smith in forum The Scream And Fly LoungeReplies: 14Last Post: 06-27-2006, 01:43 PM
  Reply With Quote Originally Posted by flabum1017
