Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 59 of 59
  1. #46
    Jul 2007
    Delray Beach
    Quote Originally Posted by flabum1017 View Post
    I was told the mechanical shift is not really mechanical.... the shift cable is hooked to a switch that controls an electric actuator that does the shifting..... and that acuator in under water..... let's see how long that lasts.
    It's digital, adaptable to mechanical controls. The actuator is internal, should last a long time. 90% of sales will be for digital.
  2. #47
    Dec 2013
    georgia
    Quote Originally Posted by altamate View Post
    Do you change your own gear case oil? Do you buy 2 cycle oil now, the Merc. stuff is not cheap. I would not miss buying it. The question should be how often do I need to change the motor oil. Likely way less maintenance and cost than adding 2 cycle oil all the time.
    Yes I change my own oil and no I don't buy mercury 2 stroke oil. I'll continue to be happy adding to my optimax. Will you be changing your own oil on your new 4 stroke every 100hrs or will u take it too the dealer. @$17.500 for motor plus $2500 for rigging I'll pass. Lol that's $17.500 for a 175hp, $19.000 for 200hp, $20,500for 225hp and it's 475lbs dry weight I'm sure it will be close to 500lbs like a two stroke when u add oil. So again is it worth it not too me
  3. Likes XstreamVking liked this post
  4. #48
    Lake Coochiching, Ontario
    $11550 for a 175 ProXS at Jaco's
    bass pro shops used to have similar pricing, may still
  5. #49
    May 2009
    Ormond Beach, Florida
    List price on the 175 Pro XS is $15,110. Compare apples to apples. Yes, the new motor is probably more expensive but the official price hasn’t been published by Mercury and we have no idea what the dealer price or street price will be.
    Mark
  6. #50
    Mar 2010
    Alberta
    Quote Originally Posted by 2jz View Post
    If/when I buy one I'll change the oil in both the gear case and the power head. The dry weight to dry weight is the fair way to compare weight. How much 2 stroke oil do you have onboard with you? I like to keep the large tank at least half full and if it's not, I'm usually hauling a jug to top it up. As it's been pointed out, you need to compare list price on both motors or wholesale on both to have a true price difference. They will certainly be a lot closer in price then some of the numbers we are seeing here.
    08 Checkmate 2100br 250xs
  7. #51
    Dec 2013
    georgia
    List price $15k for 175hp pro xs plz post link.
    I keep both 3gal oil tank full so I don't keep oil onboard
  8. #52
    MIAMI FLORIDA
    The sterndrive we had failed into reverse, had to go 20 miles in Biscayne bay in reverse to get back to the ramp, then do a Baretta maneuver at the dock.....
    The omc sterndrives were a pos but to be fair most failed from the wrong type of oil, they had spring clutches and had to have thin oil and allot of people put heavy viscosity 90w gear oil in and they would go into both fwd/rev at the same time , boom..., the outboard elect hyd was fine the wire insulation from the 60s rotted and that was the main problem.. no power was fwd, power on 1 solenoid was neutral power on 2 solenoids was rev as i remember.. dave
  9. #53
    Ft. Lauderdale, Fl
    Quote Originally Posted by H2OPERF View Post
    Yeah, the sterndrives were different.... lose power and you were stuck in reverse.............
  10. #54
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by mr fun View Post
    coupla questions, 1 how much, 2 how many hours before re-build, that's a good start. was told in the past merc is a 1000 hr engine, yami is a 3000 hr. engine. lets here some digits. FUN OUT
    I have a waterman with 12,000 hours on his mercury 150. Has had a couple sensors and a tach go bad that's it.
    any of the new 4 strokes from all the manufacturers will go thousands of hours if maintained properly.
  11. #55
    8 hrs a day
    7 days
    4 years
    Good innings
  12. #56
    Oct 2005
    savannah,ga
    Quote Originally Posted by RSWORDS View Post
    can't beat that!!!
  13. #57
    Mar 2005
    Savannah,Ga.
    Just ordered a new 150 ProXS four stroke , got a sweet-heart deal from a local dealer. Only problem is I cant get it until May! Replacing my 150 60 degree Johnson on my 1820 Actioncraft flats boat. Sure will miss the sound,smell and the punch, but am hoping for much more range.
  14. Likes WavetoWave liked this post
  15. #58
    MIAMI FLORIDA
    In the pics on the other thread it shows what looks like the electric shift actuator in the mid section spacer...below the water line , is elect shift only avail in 25in motors ? doesnt appear to be enough room without the spacer in there..
  16. #59
    Sep 2017
    Miami
    Quote Originally Posted by wtsjr66 View Post
    I think you'll like it, bullet proof engine. The large displacement makes up for the torque and the ProXS is dynod at 163 HP.
  17. Likes wtsjr66 liked this post
  1. merc 150 4 stoke oil change spout size- what diameter hose to use?
    By CircleHook in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-16-2017, 12:14 PM
  2. I Am Looking Opinions On Putting 2 300X Motors On My Cougar 22MTR!!
    By Hydrogasm in forum General Boating Discussion
    Last Post: 12-21-2016, 06:36 PM
  3. Opinions on 300X Motors- 2001 VS 2002 and Newer Models!!
    Last Post: 11-15-2016, 09:25 AM
  4. Opinions on the new Evinrude G2 Motors
    By Carter Powell in forum General Boating Discussion
    Last Post: 01-03-2015, 07:51 AM
  5. Allison 2002xb... swap 2.5L for which 4 stoke... opinions please
    By soggybear in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 04-03-2009, 09:52 PM
