Page 4 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 46 to 60 of 241
  1. #46
    Feb 2005
    Muskoka Canada
    Erik I thought that computer looked familiar, here is the three stock a6 fuel tables. Some more stuff in the background but this is most of what we need. As in I’d be jetting differently that straight 88’s
    Attached Thumbnails Attached Thumbnails FFB69D98-FBD1-4FE0-A452-63D5E8044C01.jpg
    2023 TUFF 25
  2. Likes Capt.Insane-o, texasvector liked this post
  3. #47
    shreveport,la
    Ahhh. 4% in the middle. I was thinking 6%. I see the 9% in the bottom two starts at 8500, not 9000 I was thinking
    Erik Kiser
  4. Likes texasvector liked this post
  5. #48
    Feb 2005
    Muskoka Canada
    Quote Originally Posted by patchesII View Post
    Is have to look at a13/14 maps I think they have more offset.
    2023 TUFF 25
  6. #49
    Aug 2012
    beaumont, tx
    terds.. I'm switching to carbs anyhow. ....
    air ram setup
  7. Likes Capt.Insane-o liked this post
  8. #50
    Mar 2015
    DFW
    Quote Originally Posted by texasvector View Post
    air ram setup
    I wondered if that "box" he had might have had anything to do with his tuning issues? I've seen guys build stuff like that on "ram air" hoods when we were drag racing cars and have hell tuning carbs. I'm carb stupid so no idea, just wondered.
  9. #51
    Aug 2012
    beaumont, tx
    Quote Originally Posted by Noah Burns View Post
    I'm carb stupid. . but carbs don't like positive psi so i been told.... never heard of 7 psi on fuel. ..... if i was him. .. id rip that junk ass carb vortex off the front. .. put laser/svs laser on front..... start with a48 on plus side and tune from there. ..... watchIng pistons top
  10. Likes Noah Burns, Tom Foley, RBT liked this post
  11. #52
    Found a screen shot of the stock A6. Notice the fuel at 10500? Basically a soft limiter. Drag engines usually idle around 100 kpa and when you floor it it runs up to about 157ish, running off the top row or two Attachment 399729
    If you know what your looking at this is why you don't cruise around the lake with an A6 with a stiff prop and bitch when you stick. Anyhoo..........now were getting into the cool shiz about how stuff works
  12. Likes Noah Burns, W2F a V-King liked this post
  13. #53
    shreveport,la
    I helped one guy work on his map for cruising and was surprised how much vacuum it made. Put us in this area I think
    Erik Kiser
  14. Likes Capt.Insane-o liked this post
  15. #54
    Mar 2015
    DFW
    agreed, this is the stuff that fascinates me!! Tuning EFI is cool stuff. The amount of power that lies in the tune is insane in most things. On the last race bike we built for 2017 race season we gained over 24 wheel horsepower in just dyno tuning alone.
  16. #55
    Sep 2006
    I know little about this but do have the brucato and found the difference was about 8 points between the top two cylinders and the bottom 2 and the middle at 4 but this was on a lake boat turning about 6800.
    What is meant by load on the chart?
  17. #56
    These +% numbers, are they as a result of watching, maintaining ideal temp range with positioned sensor or only HP values.
  18. #57
    Feb 2005
    Muskoka Canada
    aim dash is a blessing for this, amazing how far we have come.
    Coffeeguy, load is the the table on the left side. It is really vacuum, the top of the map is zero vacuum he bottom depending on the map if full vacuum.
    Merc wasn’t stupid, these base maps are very good. I’ve been playing with them for about 15 years, lots of dyno time and been it lots of box’s Very few times do maps very a lot. Meaning most guys arrive at the same conclusions.
    2023 TUFF 25
  19. Thanks coffeeguy thanked for this post
  20. #58
    shreveport,la
    I always come back pretty close to an A6. It really is a very good map. Mercury engineers are wicked smart and this was basically their factory race engine. It is extremely hard to improve on any of it, whether it be in the port work or the fuel map. Take the soft rev limiter out and you're pretty much there other than some minor tweaks where the boats idle in
    Erik Kiser
  21. #59
    Feb 2005
    Muskoka Canada
    Those offsets are factory merc. Very few of the guys that just play with mapping touch them. Only with lots of dyno time (pressure sensors and exhaust gas analysis) will you be able to eke much more.
    Remeber, and this was missed in fongs chest. These motors get help from above, that help requires fuel. All six holes do different amounts of work.
    2023 TUFF 25
  22. Likes Capt.Insane-o liked this post
  23. #60
    Dallas, TX
    AHHH nice. Same stuff. Here's a screencap I grabbed from the virtual machine inside my Linux PC. It's going to take a bit of work but I think I can use quite a bit of that info in the box I'm working on. Knowing the idle and WOT vacuum is a big piece to getting one started and fired up, although I'm sure as hell not going to guinea pig with a nic motor, especially a drag. LOL.
  1. 20' Action Marine restoration/resurrection.
    By Hot Shot Merc in forum General Boating Discussion
    Last Post: 08-12-2023, 02:11 PM
  2. Cosworth 275 Resurrection
    By promax150 in forum Technical Discussion
    Last Post: 07-16-2015, 08:33 AM
  3. Aquabuff-Rallysport Resurrection
    By Checkmate2.5 in forum Detailing and Care
    Last Post: 03-26-2008, 07:21 AM
  4. 2.4 Resurrection
    By Surface Scratcher in forum Technical Discussion
    Last Post: 02-25-2008, 07:49 PM
