Results 1 to 13 of 13
    Feb 2018
    Vinton Louisiana
    How to lift a 91 mercury
    As stated above I'm trying to go about the best way of doing this. I see they have a lifting eye you can buy that connects to the fly wheel but is there another way to lift it. I'm sorry its a 1991 black max 150. All my omc have little lifting ears that work great.
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    That's the best way
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
    Feb 2018
    Vinton Louisiana
    Ok will do. I've never done it like that but I'm looking to learn. I guess you pop the fly wheel nut off Then screw the threaded eye in? I was reading the newer mercury have a rubber cap that pops off then screw the threaded eye in.
    Feb 2018
    Vinton Louisiana
    I know this elementary for most of y'all hahaha. I just bought this motor and it is mint both inside and out I don't wanna jack it up trying to rig it.
    Quote Originally Posted by Duckco View Post
    Well, that will make it interesting.
  6. Likes phillnjack, 90 5.0 liked this post
    Moline,Ill
    Please leave the nut on
    is gone
  8. Likes phillnjack, 90 5.0, tux974, W2F a V-King liked this post
    Aug 2015
    Southeast
    Quote Originally Posted by BUZZIN' DOZEN View Post
    The lifting ring tools are hollow in the center to allow it to go over the nut. If you take the nut off, you will lift only the flywheel, not the entire motor. So, yes, please leave the nut on. This ebay seller has a nice tool. Threads are cut well. Not sure it will fit your year, but it's 1.5 inch x 16tpi and fit my 2002 200 perfectly. There are other sellers with crappy threads.
    Mercury Mariner Flywheel Puller 91-849154T1 Lif...
    Paid: $22.99 with PayPal
    Item ID: 372006137505
    Purchased from: heartland.products.inc
  10. Thanks phillnjack thanked for this post
    Likes phillnjack, Glasstream15 liked this post
    Pekin, IL
    It will fit just fine and be the best $23 you spend. Definitely leave the nut on.
    Rock
    Team Junk
  12. Likes Glasstream15, tux974 liked this post
  13. #9
    Find one thats also a flywheel puller, ya never know Hunt around on ebay, got mine cheap.
  14. Likes rock, Glasstream15 liked this post
  15. #10
    Baton Rouge, La
    That's what the jsre one looks like. Works fine and you can remove the flywheel with it. Mike.
    Cheaters never Win !!!
  16. Likes Glasstream15, 90 5.0 liked this post
  17. #11
    Feb 2018
    Vinton Louisiana
    Hell I was fixing to remove the flywheel inadvertently hahaha. Left the nut on got the motor picked up and mounted. A local outboard supply shop had some kits. Picked one up for 23 and taxes. Thanks for y'alls help knowledge is power.
  18. #12
    Baton Rouge, La
    You cant hardly get the flywheel off without a puller when you want to but lift one without a nut and I'm sure it would slip right off ! Good luck.
    Come over to the Amite river with me , Forbes , coupe and a few others. Mike.
  19. #13
    Aug 2002
    Sorry but i had to lmao at this one yes leave nut on!!!!
  1. Hydrostream Valero, Which Prop? need more bow lift less stern lift,
    By Dregsz in forum Props, Setup, and Rigging
    Last Post: 05-03-2018, 08:47 PM
  2. mercury lift ring
    By 250xb river rat in forum Technical Discussion
    Last Post: 10-08-2017, 06:30 PM
  3. Boat Lift, Great Lakes Lift
    By Flatlander in forum General Boating Discussion
    Last Post: 02-15-2013, 01:35 PM
