Results 2,641 to 2,655 of 4053
Thread: Fastest SOB hull???
12-28-2017, 05:13 PM #2641
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
12-28-2017, 05:46 PM #2642
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
Some cold night build details for the Laveycraft XCS 21..............
12-28-2017, 10:15 PM #2643
12-28-2017, 10:17 PM #2644
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
12-28-2017, 10:19 PM #2645
Lol, fair I was more laughing at the lamination. Nothing wrong with it just really very basic.
2023 TUFF 25
12-28-2017, 10:19 PM #2646
Greg G thanked for this post
12-28-2017, 10:23 PM #2647
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
Toffen liked this post
12-28-2017, 10:24 PM #2648
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
12-28-2017, 10:47 PM #2649
Greg you are correct the F-2 Bernico bottom was changed in 2008 to adjust C.G when our Rules changed from 2.5 to 300xs. 6.5 metor 21' 4".
Yes the front step is definitely helpful when Ballast is full to keep speeds up in the rough. A little tricky in the corners Don't trim in to much
or she will catch on the step. Mine went to the Indian Ocean last Year.
The lavey started with a 2.5 then Verado 350 and now 400. Its not F-2 legal but they can run age group and Catalina. We run together often.
12-28-2017, 10:53 PM #2650
Greg G liked this post
12-28-2017, 11:10 PM #2651
The Velocity has a couple small steps up front on the keel and the outer spray rail. This helps keep it a dry ride when rough in the corners.
The Ballast tank is just in front of fuel tank and corners with Ballast much better.
Out In Parker Skiing and testing props and Engine heights. Ran 92 today with box stock 28 Trophy
12-28-2017, 11:18 PM #2652
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
12-28-2017, 11:29 PM #2653
Yes just me 25 Gal Gas raised the engine 1/4" and gained 2 mph. We can run level to pad but running 1 1/4 below gives more lift with Weight of observer and drag from skier.
I plan to beat my best of 94mph with 32 Bravo. I am testing a 30 Promax cut to 13 3/4" tomorrow.
Does anyone know how to use the performance recall on a vessel view 7. I will try and get some photos.
12-29-2017, 11:09 AM #2654
28SkaterCa., is there an Aus Force being run here? Saw a pic of a red hull running in the Enduro by a guy named John Lynch that looked like one.
12-29-2017, 11:14 AM #2655
Supporting Member
- Jul 2004
- Connecticut
- 6,266
- 518
- 206
- 1075
- 1128
Good luck with your speed testing, be safe. Your boat (http://www.racemarine.com.au/velocity/) looks really good and I bet you have 100mph in your future.
