    Cigarette Black Tornado Stern Drives by MerCruiser...
  3. #6933
    Don Aronow's Power Choice? MerCruiser.
  4. #6934
    ...and the LIMIT UP 40' Cigarette - Power By MerCruiser...
    Docking lights give it away---
  5. Likes littlenige liked this post
  6. #6935
    Rocky Aoki circa 1977 - Rocky's Power Of Choice? MerCruiser Of Course! -
    Rocky's Choice of Power??
  7. Likes powerabout liked this post
  8. #6936
    Charles Keating Jr. ---Choice of Power?--Mercruiser, of course---
  9. #6937
    Nov 2007
    Jacksonville, FL
    Wonder if he renamed it "Stock's Way Down" a few years later?? That is...if he was able to keep it at all.
    Quote Originally Posted by GENE LANHAM View Post
  10. #6938
  11. Likes Capt.Insane-o, tux974, moparbarn liked this post
  12. #6939
    Quote Originally Posted by Ronster43 View Post
    Hi Ron--I built him a 'replacement' -- Stock's Up II--A 40' with staggered Big Blocks, Speedmasters--it was so fast none of his family would even ride in it --- called it the 'Cat Cay Taxi'--50 minutes to his home in the Bahamas---
    -Yikes!! that was over 40 years ago!!!
  13. #6940
    Too bad this doesn't include audio
  14. Likes Dave Strong, tux974 liked this post
  15. #6941
    This will have to do..Bobby gave me a signed copy the Mag it was it...(its out in the shop..)
    "The Day I Flew a Boat" by: Robert Switzer
    It all began with a phone call, (person to person) to me, Bob Switzer, from Carl Kiekhaefer, President of Mercury Marine. The date was July 17th, 1962. The meat of the call was a request for Switzer Craft to build a boat for twin Mercury 100 H.P. outboards that would exceed 100 M.P.H. on water.
    The call was impressive. Imagine ... out of hundreds of boat builders, we were called to do this project. We immediately began designing our first effort based on the pattern of the Switzer Hydro Cat (commonly referred to as the "Switzer Wing"). In 1961, the Switzer (U4) wing was a major breakthrough in the twin engine Stock Outboard Pleasure Craft Class U. (Unlimited engines but required to be a minimum of 15 feet in length.) The first Switzer Wing was built in 9 days, just prior to the Winnebago Outboard pleasure craft event, where the Switzer Craft Wing finished first overall, and the next two classes were also won by other Switzer models. The U4 was the first Cat to exceed 80 M.P.H. with only a pair of 76 cu. in. 80 H.P. Outboards. (see below)
    Our first new design developed to meet Mr. Kiekhaefer's request was not a complete success. At speeds of over 85 M.P.H. the bow had a tendency to kite or "bow up" (a feared maneuver of every driver).
    In late August, we tried a new hull concept, mounting the engines mid-ship in a hull much like the Hickman Sea Sled. It featured square simple lines and a shovel nose. We hoped that the engines forward could control any bow lift tendencies. Much to our regret the trial runs showed that the thrust of the propellers forward and under the hull clamped the back of the boat to the water and drag was too much for our twin 80 H.P. Mercury's to overcome in the initial plane off.
    Time was slipping away, the leaves were turning into their fall colors and we estimated approximately five weeks of open water to test on the Fox River near our plant. A decision had to be made... Do we call Mr. Kiekhaefer and postpone the project until spring, or do we keep going "right up to the wire" as the saying goes. The decision was made! Keep going!
    My brother, Dave Switzer was the designer in charge of the construction phase of this project. He knew that now the pressure was on to design and build that 100 M.P.H. boat in minimum time. Russell "Pop" Switzer, a pioneer in light aircraft and sea planes since World War I, injected some new ideas he had long thought were necessary to control a boat at flying speeds. Dave welcomed these new ideas and also accepted a weight distribution change that I had recommended. We also concentrated on making a cleaner air-flow version of his original U-4. Several days later the materials were flying into shape and the U-6 hull was finished in record time. With time running out fast it was rigged for the first test runs.
    The time was now! We proceeded to the test area on Nov. 29th, 1962, only to find that there was a 1/4" of ice on the river, stopping all progress. The weather reports promised warmer weather for the next day. All was held in readiness. November 30, temperature 45° -Sky clear -water open and calm. Time, 10:00 A.M. we launched the U-106. I got into the enclosed plexiglass cockpit (much like the capsule boats of today) , checked out all instruments, fired up engine #1, check, #2, check, water pressure and cooling systems OK, tachometer reading steady, fuel pressure normal, closed the aircraft type canopy over the cockpit, bring the engines to warm up speed and taxi to position for a wide open run.
    Now, increasing speed to 50 mph -60-70 -80 and now at the speed range where the previous design started to kite I used the foot throttle over-ride and steering with my left hand, I put my right hand on "Pop" Switzer's stabilizing control lever which operated the elevon (wing tail flap) controlling the last 2 feet of the center section between the twin hulls. At 85 M.P.H. the bow lifted slightly off the horizon - too high for safety, I pushed the lever forward to position 1 ( of 4) and the horizon line returned to normal. Now, at 90 M.P.H. a slight bow lift again, lever to position #2, now the bow was normal in good trim again. Suddenly, at this moment many things seemed to occur. While my 17 pitch (Record props from Switzerland) were turning almost 6,000 R.P.M. my neck snapped back, the Hull lifted off the water about 2-4 inches ... no vibrations from water contact. I felt like I was in a sea plane just after lift off of the water. The R.P.M.'s suddenly dropped back to approximately 5,000, and at the same time the speed increased to the shrill sound of the two engines harmonically balanced. I glanced down at the Keller calibrated speedometer, reading 96-97 -98-99 -100 with those 76 cu. in. 80 H.P. direct reversing engines revving at nearly 7,000 R.P.M. I knew we had just what Mr. Kiekhaefer asked for. Now, almost tranquil from the experience of "The Day I Flew a Boat" with a full boundary layer of air between the hull and the water and seeing houses go by like a picket fence. I realized that the straight away water was fast running out. So, deceleration of the U-6 was started with the same caution used in increasing the speed. The stabilizer control was returned to various positions as the speed was reduced. When the boat speed was between 80 and 85 there was a loud sound and vibration from the hull re-entering the water almost like driving from the highway to a washboard gravel country road. Taxiing to the launching site where all the Switzer Craft crew were on hand for the verdict I could hear all the questions. How did it handle? How fast did it go? What was it like? .....And, you know the answers.
    The Hull was then returned to the factory for final preparations to be delivered to Mr. Kiekhaefer at Lake X where she was fitted with a pair of 99 cu. in. 100 H.P. engines with stacks and double pinion speedmasters. She went on to reach speeds in excess of 120 M.P.H. This same hull driven by both Johnny Bakos and Dave Craig startled many of the onlookers and the Helicopter pilots that could not keep up with her to allow the photographers to film her, as she won the Gold Coast Marathon from Miami to Palm Beach and return on the inland coastal waters, with a record average speed of 81.78 M.P.H. that may still stand today!
  16. Thanks powerabout thanked for this post
    Likes msm liked this post
  17. #6942
    Dec 2001
    Just think of hilly screeching.....
  18. Likes Capt.Insane-o liked this post
  19. #6943
    Dec 2001
    I think I just ruined this thread..... sorry.
  20. #6944
    Jul 2013
    That's an awesome read! Thanks for posting.
    The first time becoming completely free of the water and flying in ground effect. Must have been quite a combination of exilerating and frightening being in such uncharted territory.
  21. #6945
    Gotta tell ya story the "hold my beer/the hell it can't be done" heydays back then. Friend mine had a W/E lake house channel off Pistakke the Fox chain, Illinois. Lived the burbs, but LIVED for the W/E's the lakes! Bobby lived down river in McHenry. Back in the 70's, Glenn who owned the house had Bob custom build a 1974 Switzer, SS 17. with the new Blue Strip XS1500. Bobby and Dave built the boat, "Uncle Ralph" (what we called him) and Merc GURU!" Ralph Kozan massaged the motor. Rigged at Fox Lake Harbor owner and Outlaw sprint driver (King of the cushion). Well I had a 13 Ally, and Glenn sold me the boat as wanted newer. Al I did drive the piss out that witch, and did red stripe decals to match the boat. But Carl Larson next door us had a GL20/200 Rude.
    So one day here comes up the channel this red boat? Yep, Bob and Carol and the doggy in the new GL21, with 235 Rude! Damn, "there goes the neighbor hood)! Soon the big Rudes were showing up on Allisons with big Rudes Thursday nite drags at Blarneys. Damn fun great times!
    Later as moved west coast, did a road trip back Illinois for a all year grad HS picnic 2006. Had arrangements to meet again Bob at his house. but he was busy and we talked a gas station. His article "The day" was in Extreme Boats mag..volume 3.4. Saved me a copy, and we went on our ways.
    Wish we had took more pix then, but to busy "doing life'!
    Some pix, my boat as Carls. I too old to make new mems, but the ones I got are "priceless"!
Name:	Switzer Roostertail.jpg
Name:	Switzercraft and crazy Jimmy (Jimmy).jpg
Name:	Switzercraft at 72 MPH.jpg
Name:	Carls 20 200hp and the dog.jpg
Name:	Carls 20 200hp.jpg
Page 463 of 1894 FirstFirst ... 363 413 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 513 563 963 1463 ... LastLast
