Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 15 of 113
    Looks too loose to me ..
    I think the center hole has a problem ...
  2. Likes Slimm, NICE PAIR, Dave Strong liked this post
    Loose is fast right?
    Looks like it is getting a little more use than the others as well...
    Maybe I can fix it ....
    https://i.imgur.com/LiObFIk.mp4
  5. Likes NICE PAIR, Kcraft liked this post
    One of the easier remedies for you I guess...
    Im sure you have a tighter fitting slug for that bore
    That link is a short video . I haven't got a handle on a good place ( besides slow loading you tube ) to load vids .
    Link : https://i.imgur.com/LiObFIk.mp4
    Besides the torque from the increase in displacement . The port window's get much wider even when sticking with Mercs conservative port width / bore ratio ..
    Bore/port width ratio reasoning?
    3.999999 liter ???
    Quote Originally Posted by NICE PAIR View Post
    3.999999 liter ???
    You are pretty close...
    For any kind of ring life 70% of bore diameter is considered the end of the road .
    A stock 300x works off of a 64% ratio @ 2.330"
    To bore one of these out "bigly" would bring the port width ratio down to 60% which would leave a lot on the table .
    It's been pretty much relized that the most critical width area is in the first 30* of the ex ports opening .. that's why you will see people going to an Opti - elliptical window , which is easier on the rings and skirt life .
    Anyway ..
    Going out to 2.500 brings you back in line @ 64%
    And even going to 2.600 brings you in @ 67%
    As a side benefit , having a lot of meat that needs to be cleared out of the port , lets you contour the radius to ones own liking ... well OK , more twords what the windmill liked ..
    Nice Pair :
    3.999999 liter ???
    As Joe says ... Close
    Chaz = thinking , after taking a quarter inch of material out of each hole ... Pppffftttt these things can go out another eigth inch ... easy ...
  13. Thanks MeCapnDave thanked for this post
    Likes Capt.Insane-o, JrCRXHF liked this post
  14. #11
    MIAMI FLORIDA
    All these years us rude boys have been trying to turn them into mercs now u merc nuts are trying to turn them into rudes..Looks nice but need some omc tractor rods in there lol...
    Gothenburg, Sweden
    Good that you caught the intruder piston before you put the head on.
  16. #13
    OK Chaz, thanks for taking the time to explain it. Again, I was over complicating things by thinking bore size/port velocity interaction. The 30* fact or initial port exposure always did seem to me the most critical time to get things headed in the right direction though.
  17. #14
    Quote Originally Posted by H2OPERF View Post
    I don't know nuffin boutz where dem pissons had be .. Jus like Liberty City , I din-do-nuffin ..
    I would had use a tracker rod .. but I cooden fine a shorty skroke crank to fit my blok ..
    Markus
    So 10 years ago, Todd D gives me a set of billet head that had most of the chambers cracked . They sat on my shelf for a few years . A local OMC guru borrows one , redesign's the chambers and takes it to "my" CNC guy . They reprogram the bolt hole pattern and run off a bunch of sets .
    Some time later , I take "my" head to the "use ta be" my CNC guy and say run me a set , but with the Merc bolt pattern ... Wait , I gotta get permission from the OMC guy first ....
    LOL .. so I guess you could say , I gotz OMC / BuRP heads too ...
    AZMIDLYF
    That one was easy . I wish I could claim it , just another step in two stroke evolution . Shame that most of the world has given up on them , no telling where they would be by now ...
    300x on the left .... 300xs on the right ...
  18. Likes MeCapnDave liked this post
  19. #15
    Both stock sleeves? If so..wow that is a startling difference. Aside from the obvious size difference and the naked eye observation, is the X exhaust port opening sooner and closing sooner than the XS?
  1. Queston for US1, JSRE or Greg Moss. How loose is too loose??
    By DUCKY in forum Technical Discussion
    Last Post: 08-30-2019, 04:43 PM
  2. About to loose it!
    By ufish2 in forum Technical Discussion
    Last Post: 11-17-2013, 06:55 PM
  3. Mercury Tech: my prop is loose.....
    By Surfer Dave in forum Technical Discussion
    Last Post: 04-21-2010, 03:11 PM
  4. Hey Andy,Loose Something?
    By Capt.Doug Metko in forum The Scream And Fly Lounge
    Last Post: 02-15-2007, 05:44 PM
  5. 17' baker too loose
    By tres in forum Props, Setup, and Rigging
    Last Post: 03-20-2004, 01:04 PM
