Results 16 to 26 of 26
Thread: What is the best drag foil
09-11-2017, 02:04 PM #16
09-12-2017, 07:58 AM #17
After reading this I went back and zoomed in to have a closer look. that is some very nice work indeed.
very cool customisation .
02-21-2019, 06:02 PM #18
5000 RPM
- Mar 2011
- La.
- 107
Where can I get one for a Mercury ProXS 250?
02-21-2019, 06:04 PM #19
5000 RPM
- Mar 2011
- La.
- 107
02-21-2019, 08:14 PM #20
Cb marine design or CDR (they make them in carbon fiber)
Boat: Hydrostream virage
Engine: Mercury 300 XS DBR 1.3
Props: Buckshot gen2 4 blade cleaver 14,75 x 34' pitch
Max speed: 114mph
02-23-2019, 10:26 AM #21
I think the guy is on BBC selling them , nice piece,
03-01-2019, 03:39 PM #22
6000 RPM
- Feb 2014
- Missouri
- 1,211
- 66
- 12
- 83
It won’t help much if you’re slipping out (just spinning to 5k and not moving)
if you’re venting ( sucking air from the surface) then it will help.
I also caution about hooking on a turn.
03-01-2019, 08:48 PM #23
Team Member
- Lake Coochiching, Ontario
- 8,485
- 43
- 406
- 671
- 2143
- 6 Post(s)
My Bobs True Tracker completely solved the 5000 rpm take forever to plane problem on my Virage. I can remember my brother and I looking at each other in shock.
03-02-2019, 08:17 AM #24
Screaming And Flying!
- 15,137
- 416
- 1478
- 6114
- 11812
The bobs can break your cav plate.......I have 2 lowers with broken cav plates to prove it....They are cast and very stiff. They do work well design wise. I like them in use but am scared to run them.
Dave Strong liked this post
03-02-2019, 04:28 PM #25
Team Member
- 8,485
- 43
- 406
- 671
- 2143
- 6 Post(s)
I've been using the Ally foil on my SS2000 for about 6 years. Actually I've never driven the boat without a foil.
03-02-2019, 10:20 PM #26
6000 RPM
- Feb 2014
- Missouri
- 1,211
- 66
- 12
- 83
I like them just not running above water like my current set up.
Familys 18.5” 72 30”deep v loves them. So does the pontoon can actually trim it. My tracker though doesn’t like them since I’m high enough to come above the surface.
I will say a lot of sporty need more anti vent plate. Especially when swinging more then 28” close to the surface. Real easy to blow a whole in the water exposing the prop to air.
Honestly i I would look for about a 4” wide add on plate positioned over the blade tips. Then go up from there.
Georgian bay Drag foil 2.0
By Mitchie in forum General Boating DiscussionReplies: 8Last Post: 05-09-2014, 08:02 PM -
Anyone ever made a Drag Foil??????
By mrtsrt in forum Technical DiscussionReplies: 5Last Post: 07-16-2013, 02:27 PM
