Results 1 to 5 of 5
    Jul 2014
    wisconsin
    help with jackplate on 1980 baja ss
    looking to set my rig up with a 8 or 10 inch jackplate.what do you guys think on set back.20 foot boat 200 mercury.
    Lake Coochiching, Ontario
    Sound like a good idea if the hull is sound.
    Feb 2014
    Missouri
    Set back is determined by speed and hull. Well proper setback is. It can also be used for bow lift. I would say 6-8 if under 60 10+ if over is a good rule of thumb. Hull prop ect will affect that.
    May 2001
    Maine
    I had a 1992 Baja 186 with a 2.0L 150 Mercury with a few small engine modifications. I installed a Land & Sea Jack which I believe was about 6" of set back and then after sea trials added a set of Bobs 2" blocks as I still had to trim to get the bow up. This gave me a total of about 8" and made a huge improvement. I gained a few hundred RPMS and gained about 4-5 MPH as I was able to go from a 23" laser II to a modified Rich Booger 25" Tempest.
    Jan 2015
    Quote Originally Posted by terry1 View Post
    You might want to run a search for this boat specifically. Some hulls do not like much set back, others like a bunch. Better to find someone who has done it already and copy them. Unless you have a ton of time and money, then by all means, trial and error work too.
    And it was mentioned above but I am gonna say it again, make sure your transom is good. If it has not been replaced, likely it will have issues. The further you move the motor away from the boat, the more stress you put on the transom. And do not try and brace it with metal and such.
  1. Replies: 12
    Last Post: 04-17-2016, 10:59 PM
  2. Need outboard advice! 1980 Baja 20BR w/ Merc 225
    By londt in forum Props, Setup, and Rigging
    Last Post: 04-30-2014, 06:59 PM
  3. IllinoisRiverRat 1980 Champion Swift/1980...Prop setup
    By IllinoisRiverRat in forum Props, Setup, and Rigging
    Last Post: 07-31-2013, 09:57 PM
  4. Do I need to replace the foam/1980 Baja
    By mdsv16 in forum Fiberglass and Composites Discussion
    Last Post: 04-30-2008, 05:01 PM
